How does an inertial force affect water movement in an open channel?
The discussion revolves around the effects of inertial forces on water movement in open channels, particularly in the context of water discharged from a pipe into a larger body of water. Participants explore various scenarios and calculations related to the displacement and movement of water caused by this discharge, with a focus on practical applications such as aerators and circulators in lakes and ponds.
  • Homework-related
  • One participant describes a scenario involving a 1" pipe discharging 10 GPM into an open water body, seeking to understand the effect of this discharge on surrounding water movement.
  • Another participant suggests that the problem requires a more specific scenario to facilitate calculations, proposing a circular swimming pool as a model to analyze the induced circular motion from the inflow.
  • A different participant simplifies the question by asking how much water is moved when a gallon is poured into a larger body, proposing that the inertia from the displacement could result in additional movement.
  • One contributor mentions the Poiseuille equation for laminar flow and highlights the challenges of calculating turbulence and mixing in open water systems.
  • Another participant expresses uncertainty about quantifying the effects of water discharge and acknowledges the speculative nature of their calculations, while seeking proven formulas for these dynamics.
Participants do not reach a consensus on the best approach to calculate the effects of inertial forces on water movement. Multiple competing views and models are presented, indicating a lack of agreement on the specifics of the problem and the methods to analyze it.
Participants note limitations in their descriptions, including the need for clearer definitions of scenarios and the complexities introduced by factors like turbulence and friction. There is also an acknowledgment of the speculative nature of some claims and calculations.
FloridaNick
I am working on a project where I have to calculate the affected water movement in an open channel. What I mean by affected water movement is the gallonage moved by an inertial force such as a stream of water discharged under pressure.
For example:
A 1" pipe is discharging 10 GPM into an open water body parallel and just below the water surface. For the example there is no wind or restrictions. What I know is that the water is flowing at 10 gpm which displaces 10 gpm at the discharge. now I need to know the effect that discharge has on the water around it. All assumptions are the water is the same temperature, no wind, fresh water etc..
Supposed to be a straight forward calculation but I can't wrap my head around it.. Anyone out there that can offer a solution?
Thanks
FloridaNick said:
I am working on a project where I have to calculate the affected water movement [...]
In the form presented here the problem is insufficiently described. There are too many scenario's, you cannot possibly cover all possible scenario's in one swoop.
It seems the only way to do any work is to narrow down the setting, to a form so symmetric that it lends itself to calculation.
For instance, let the open water that receives the inflow be a circular swimming pool with vertical walls. Let the inflow be in horizontal direction, parallel to the perimeter. Then the momentum of the inflowing water will induce circular motion, and you can calculate how much circular motion. Then you are in a position to try and put in estimations of friction. (Gyrating water in a swimming pool comes to a halt pretty quickly, so friction is a significant factor.)
Sorry about being so vague but the problem is for open water systems like lakes and ponds. Trying to determine the flow rates for different aerators and circulators. To determine the proper flow rates you have to figure out how much water is moved by moving the water.
To try and simplify the question... If I pour a gallon of water into a large body of water, how much water does the gallon move?
I can assume that 1 gallon of water will displace 1 gallon of water. The inertia from the displacement of 1 gallon of water will continue for 3 seconds (just a number for the sake of argument) slowing to a stop. So what is the best way to figure out the total movement in Gallons.
I could argue that 1 gallon of water when poured in a water body will move 4 gallons of water ( a gallon per second plus the first gallon moved) plus the initial gallon so that would make a total of 5 gallons moved. So for every gallon pumped in or moved I can count 5 gallons of movement.
That is a total guess and is probably wrong. So I am looking to find someone who might be able to provide a proven formula for this type of movement or energy.
Thank you for the reply and I hope this explanation helps.
I guess you have known input of momentum, and also by the Poiseuille equation (laminar friction in the channel) known output of momentum.. you might also need to account for the slightly varying heights of water around the channel circuit.. as a rule though, turbulance (mixing) is one of the more difficult things to try to calculate. You might get better estimates from engineers than physicists.
I have the initial input of water at 16 GPM (6 ft/sec) via 1 inch discharge into an open water body. The Poiseuille equation is for flow inside a pipe.. This is more of the after effects of water discharge. It does not have to calculate to the end of the inertia, just the first few seconds.
I can calculate the weight and velocity but it is all speculation nothing quantifiable. I can guess with the best of them but I don't think that is what physics is all about.
The argument could be made (with much speculation) that throwing a pebble into a lake will move every gallon over time but that is quite silly.
I have searched and searched for proven formulas but cannot find them.
Thank you to everyone who has posted so far. I truly appreciate the brain power... Please keep em coming
  • · Replies 32 ·
12K
  • · Replies 17 ·
  • · Replies 28 ·
  • · Replies 20 ·
12K
