How does diffraction cause interference
1 reply · 4K views · last reply
peter.ell
Light normally doesn't interfere with itself because it is incoherent and unpolarized, right? So how is it that incoherent, unpolarized light passes through a circular aperture and interferes with itself?
How does the aperture suddenly cause the light to be able to interfere with itself? In essence, isn't light passing through a circular aperture the same as light being emitted from a circular source the same size? If so, then I would expect a small circular light source to show interference patterns, yet it doesn't, why not?
Thanks so much.
To get interference you need a very small aperture, the same order of magnitude as the wavelength of the light, so that each photon will be coherent across the aperture, even though the light beam as a whole is incoherent. Plus the beam needs to be monochromatic, so that each photon adds its contribution to the same interference pattern.
Name an incoherent source as small as a wavelength of light? Better: consider a long wavelength example, like radio waves. Two antennas a wavelength or less apart, coherent with each other, will an exhibit interference pattern.
