How does electric current change electric potential?
Injecting current into an electrically insulated box increases its electric potential, with the change in potential depending on the box's capacitance. The relationship is defined by the equation V = Q/C, where Q is the charge and C is the capacitance. When current (I) is injected for time (t), the charge increases to Q + It, leading to a new potential difference. Higher capacitance means that more charge is required to achieve the same increase in potential, analogous to needing more water to raise the level in a larger container. Thus, the effect of current on potential diminishes as capacitance increases.
Apteronotus
Suppose we have an electrically insulated box in a room, and the potential difference between the box and the room is given by V_1=V_{Box1}-V_{room}.
Now suppose we inject the box with X amps of current, for t seconds. The new voltage is now given by V_2=V_{Box2}-V_{room}
By how much does the injection of X amps of current change the electric potential of the box?
ie.
What is V_{Box1}-V_{Box2}?
It depends on the capacitance of the box. V=Q/C
and Q = It
Your current has placed more charge on the box so its potential will rise according to the value of its capacitance.
Edit
Use V=Q/C and write an expression for V1 and V2 in terms of the charge on the box and its capacitance.
So can we equate the two equations you've written and simply say CV=It?
Also,
if the box is a good electrical insulator, then we expect it to have a high capacitance (ability to hold an electrical charge), right?
But then by the CV=It above, the higher the C is the less effect a current I will have on the potential V. What's the intuitive meaning behind this?
The initial pd on the box is given by V1=Q/C where Q is the initial charge and C its capacitance.
The final pd of the box (V2) is found by putting the charge on it equal to Q + It (and the same value of C.)
You then find V2 - V1
Also,
The definition of C is that it equals Q/V
The intuitive part of this is that the higher the value of C, the more charge you need to increase the pd. So as current is flow of charge, the higher the capacitance means that you need more current to increase the pd.
I always think of water in a container. The pd is the depth of the water, and the capacitance is the capacity (volume) of the container. The bigger the capacity of the container, the more water you need to raise its level.
If you were filling it with a hose pipe, you would need a larger water current to fill a larger container to the same depth in the same time.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
