How Does Electric Field Direction Affect Electron Path in Parallel Plate Setup?
7 replies · 9K views · last reply
PFStudent
7. In Fig. 28-35, an electron accelerated from rest through potential difference [tex]{V}_{1} = 1.00{\textcolor[rgb]{1.00,1.00,1.00}{.}}kV[/tex] enters the gap between two parallel plates having separation [tex]d = 20.0{\textcolor[rgb]{1.00,1.00,1.00}{.}}mm[/tex] and potential difference [tex]{V}_{2} = 100{\textcolor[rgb]{1.00,1.00,1.00}{.}}V[/tex]. The lower plate is at the lower potential. Neglect fringing and assume that the electron’s velocity vector is perpendicular to the electric field vector between the plates. In unit-vector notation, what uniform magnetic field allows the electron to travel in a straight line in the gap.
http://img228.imageshack.us/img228/4953/platepicgl6.jpg
[tex] {\vec{E}}_{p1} = {\frac{\vec{F}_{21}}{q_{2}}}[/tex]
[tex] {\Delta{V}_{p}} = {-}{\int_{r_{0}}^{r_{1}}}{\vec{E}_{p1}(r)}{\cdot}{d{\vec{r}}}[/tex]
[tex] {\vec{F}_{B}} = q{\vec{v}}{\times}{\vec{B}}[/tex]
Ok, this problem does not seem that hard, however the wording isn’t really clear. So let me see if I understand this problem, you have an electron being accelerated by [tex]{V}_{1}[/tex] into an electric field produced by two plates. Where the bottom plate has potential [tex]{V}_{2}[/tex].
Ok, so my question is if the bottom plate has potential [tex]{V}_{2}[/tex], does the top plate have a potential?
Also, what about the electric field between the two plates how can you tell in what direction the electric field points in?
Any help is appreciated.
Thanks,
-PFStudent
Hey,
So, I was looking at this problem again and I am still not all that sure about how you can tell which way the electric field points? How is that you determine that in this problem?
Thanks,
-PFStudent
The electric field points from higher to lower potential, which can be seen from this equation of yours (that's the meaning of the minus sign):
Hey,
I was looking at this problem again and had a quick question. When finding the potential difference,
[tex] {\Delta{V}_{p}} = {-}{\int_{r_{0}}^{r_{1}}}{\vec{E}_{p1}(r)}{\cdot}{d{ \vec{r}}}[/tex]
Do you always integrate from the lower potential to the higher potential? In other words when finding the Electric field would I integrate from,
[tex] {r_{0}} = {-{\frac{d}{2}}}[/tex]
to
[tex] {r_{1}} = {+{\frac{d}{2}}}[/tex]
So, that the integral would look like the following,
[tex] {\Delta{V}_{2}} = {-}{\int_{{-{\frac{d}{2}}}}^{{{\frac{d}{2}}}}}{|{\vec{E}}_{}(r)|}{}{|d{{\vec{r}}}|}{cos\theta}[/tex]
Where, [tex]{\theta} = {180}^{o}[/tex], since [itex]\vec{E}[/itex] points downward (from the higher potential to the lower potential) and [itex]d{\vec{r}}[/itex] points upward from [itex]{r_{0}}[/itex] to [itex]{r_{1}}[/itex].
Is that right?
Thanks,
-PFStudent
Note that you are always finding the potential of r_1 with respect to r_0. If you reverse the integration (integrating from r_1 to r_0) the sign changes:
[tex]\int_a^b Fdx = -\int_b^a Fdx[/tex]
So it doesn't really matter which way you integrate. What does matter is the direction of [itex]\vec{E}[/itex] compared to [itex]d\vec{r}[/itex].
Hey,
Forgot to say thanks for the above info. That information had helped me better understand how to solve these type of problems. Thanks.
Ah...yes I do remember that. Thanks for reminding me.
Ok, so then on the below integral,
Do I have the limits correct?
Ok, so was I correct in performing the integration the way I did, Where [itex]{\theta} = {180}^{o}[/itex], since [itex]\vec{E}[/itex] points downward (from the higher potential to the lower potential) and [itex]d{\vec{r}}[/itex] points upward from [itex]{r_{0}}[/itex] to [itex]{r_{1}}[/itex]?
Also, since you mentioned that propery of integrals--I could alternatively intregrate the following way,
[tex] {\Delta{V}_{2}} = {}{\int_{{{\frac{d}{2}}}}^{{{-}{\frac{d}{2}}}}}{|{\vec{E}}_{}(r)|}{}{|d{{\vec{r}}}|}{cos\theta}[/tex]
Is the above integral correct also?
So, in the end was the below integral correct?
Thanks so much for the help,
-PFStudent
Yes. You are finding the potential difference of r_1 with respect to r_0.
Absolutely.
Yes indeed.
You bet.
Hey,
Thanks for the help Doc Al! :smile:
Thanks,
-PFStudent
