How Does Electric Field Direction Relate to Equipotential Lines?
5 replies · 3K views
bbuilder
The equipotential curves in a certain region of an equipotential diagram in an xy plane are parallel to the y-axis and are equally spaced. The potential is increasing in the +x direction. Which direction would an electric field vector point in this region?
N/A
The equipotential lines are vertical, so the electric field lines must be in the x-direction since they run perpendicular to each other. Would they point in the positive x direction since the potential is increasing there? I'm having a hard time picturing what this would look like.
Try to relate electric field and potential/potential difference- is there any formula by which potential can be written in terms of electric field? Think about it and let me know if you have any question.
Best of luck!
I know that V=∫Edl, but I'm having trouble connecting that to what the equipotential lines would look like.
Suppose the field is created by some distant pair of opposite charges, one in positive x direction and one in the negative. Will the potential be higher towards the positive charge or towards the negative? Which way will the field point?
I know that V=∫Edl
No, it's V=-∫Edl. In differential form: E = -dV/dl (or -dV/dx in this context). You're told the potential increases with increasing x, so what is the sign of dV/dx?
The potential would be the same at both a positive charge and a negative charge because potential is scalar. The electric field would point towards the negative charge.
The sign of dV/dx is positive, but when the negative sign is taken into account then E is negative, so the electric field is going in the negative x-direction. Is this correct?
Eh?! Is +3V the same as -3V?
Yes.
