How Does High Dark Current Impact Solar Cell Performance?
  • Thread starter Thread starter spoonfeeder
    Current
High dark current in solar cells can negatively impact their performance by reducing efficiency and increasing noise. It represents a small electric current that flows when no light is present, which can lead to energy losses. The direction of dark current typically flows in the same direction as the photocurrent, complicating overall device operation. Understanding the implications of high dark current is essential for optimizing solar cell design and functionality. Addressing dark current issues can enhance the overall efficiency of photovoltaic systems.
spoonfeeder
I know how dark current is produced, but what if its high and how does it affect, say solar cell?
Ironic user name, eh?
What can you tell us about dark current? What have you read about it so far? Is dark current good or bad in solar cell operation?
Is dark current anything like the black oil on the "X-Files"?
It’s a relatively small electric current that flows through a photosensitive device when no photons are entering the device.
How does it affect the device when its high?
Which direction does the dark current flow? In the same direction as the photocurrent, or opposite?
EDIT -- Even more to the point, Google this for some helpful articles -- photovoltaic cell dark current
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
