How Does Mass Affect the Acceleration and Distance Traveled by Falling Objects?
12 replies · 4K views · last reply
Ilovepysics
A penny with mass of 3.1 grams is dropped from skyscrapper of height 1250m. Find the objects acceleration after 5 secs. If a penny with mass 2.5g is dropped at this point how far does it travel before the first penny hits the ground?
Kinematic equations; f=ma.
Is there any additionally information for the problem? The question is stated in such a manner that it leads me to believe there should be some air resistance. If there is no air resistance, the penny will accelerate at a constant rate of 9.81N/kg.
Remember Galileo's experiment (assuming no air or other resistance).
Two objects dropped from the same distance will fall for the same amount of time regardless of its mass.
So how long does it take penny A to hit the ground?
After you figure that out, how long is penny B falling before penny A hits the ground?
(hint: penny B is dropped 5s after penny A)
After you figure that out, how far does penny B fall in that amount of time?
Hope this helps!
@ Sandy.bridge - yes that is all the information given. So assuming air resistance is negligible the first penny has an accceleration of 9.81N/kg??
What about the second penny?>>> If a penny with mass 2.5g is dropped at this point how far does it travel before the first penny hits the ground?
Thanks labguy!
But how can I find how long it takes penny A to hit the ground if I don't have value for v?
Can I use. d= vit + 1/2 at^2 and make vi=0?
Ilovepysics said:
Thanks labguy!
You do have a value for v (actually vi). It is zero! That is, it starts at rest.
Thanks all! I worked it out using d= vit + 1/2 at^2.
-Found time it took penny A to reach hit ground ~15 secs.
-Time for penny B is 15 + 5 secs= 20s
-Then using d= vit + 1/2 at^2 found how far penny B lands. 2000m.
Can someone please verify if this is correct??
It seems your rounding is way off ... the time for penny A is closer to 16 secs.
Also, the problem isn't asking how long it take penny B to hit the ground (it would take the same amount of time as penny A). Rather, it is asking how far penny B falls before penny A hits the ground. (Besides, it can't fall more than 1250 m, so 2000 m can't be right)
I tried labguys approach by finding the time and such. Should I go about it differently? If so how?
1) Determine the time it takes for Penny A to reach the ground from the time it is dropped
2) 5 seconds later Penny B is dropped, so find out how much time is left for Penny A to reach the ground
3) How far does Penny B travel in that time?
just a hint : the second penny travels for 16-5 seconds...
do the math now !
Penny B travels 605 m . Got it! thanks everyone!
