How Does Newton's Third Law Apply When One Block Pushes Another?
  • Thread starter Thread starter aeromat
    Block
In the discussion on Newton's Third Law, two blocks of mass m1 and m2 are analyzed under the influence of a constant force F applied to m1 on a frictionless surface. The key focus is on determining the acceleration of the system while considering the action and reaction forces between the blocks. It is clarified that the force exerted by m2 on m1 is equal in magnitude but opposite in direction to the force m1 exerts on m2. The problem simplifies the analysis by treating both blocks as a single unit for calculating acceleration, despite their differing masses. Understanding these forces is crucial for solving the problem accurately.
aeromat
Problem Type: Derivation
2 blocks of mass m1 and m2 are placed in contact with each other on a smooth, horizontal surface as in the figure below. A constant force F is applied to m1 as shown.
(a) find the acceleration of the system
Newton's Laws
Picture of the problem:
F
-------> [ m1 ][m2]
Frictionless surface assumed.
FBD Sketch (are the action and reaction forces equal in magnitude?)
For m1:
Applied force -----> [ m1 ] <----- Reaction force by M2?
Fn and Fg are present.
For m2:
Applied force by m1-----> [m2]
Is the reaction force received by m1 pushing m2 equal in magnitude but opposite in direction to the applied force on m1?
Because the problem is only asking you the acceleration of the system, you can safely consider m1 and m2 the "same" block.
Remember, don't confuse yourself with free-body-diagrams. Usually only consider a force for calculation if it results in acceleration. In this case, the only force causing acceleration is the push (or friction, if it specifies).
But wait, the picture of my diagram states that the m1 mass is much bigger than the m2 mass. So, how would this work out? I am getting really confused with the action/reaction forces, and I don't know how I would work without them.
The force exerted by m2 on m1 is equal (in magnitude) but opposite (in direction) to the force m1 exerts on m2.
I would call this the reaction force.
I would call this the action force.
11K
