How Does String Tension Affect the Sound of a New Musical Instrument?
The discussion revolves around a new musical instrument made from a metal can and a string, focusing on the relationship between the tension in the string and the sound produced. The problem involves understanding the harmonic frequencies of both the string and the can, and how changes in tension affect pitch and intensity.
  • Participants discuss the mathematical relationships between the speeds of transverse and longitudinal waves, questioning the validity of initial equations and assumptions. There are attempts to sketch waveforms and relate them to the problem, with some participants expressing confusion about the underlying concepts.
Several participants are actively engaging with the problem, offering sketches and equations while others express uncertainty about their understanding. There is a mix of attempts to clarify concepts and correct misunderstandings, with some guidance provided on distinguishing between different wave types and their relationships.
Participants note the importance of correctly defining variables and understanding the physical setup of the problem. There are mentions of imposed homework rules and the necessity of reasoning through the physics rather than relying solely on memorized equations.
Emily_20
A new musical instrument is fashioned from a metal can of length L and diameter L/10, open at one end, with a string stretched across the diameter of the open end. The string is tensioned such that the 3rd harmonic frequency of the vibrating string matches the fundamental frequency of the can.
a) What is the mathematical relationship between the speed vt of transverse waves on the string and the speed va of longitudinal waves in the can?b) What happens to the sound produced by the instrument if the tension in the string is doubled? Describe what happens to both the pitch and the intensity, and defend your answer with an argument as quantitative.
Fn = nv/4L, v=f *lambda
a) 3v/4L=1v/4L
Fcan= Fstring
b) The frequency goes up.
I need help with these two questions.
a) 3v/4L=1v/4L
... You have just written that 3=1 (multiply both sides by 4L/v) - this is false.
The frequency formula you have written above does not work for both can and string.
You need to distinguish between the speed values for the can and the string.
If you sketch the wave-form, instead of relying on picking the right equation, you should be able to relate the lengths in question to the wavelengths of the waves.
The equation you want is ##v=f\lambda##
The problem is that I do not even know how to sketch the wave-form. I do not even think that I understand what's the point of this problem.. maybe that's why I cannot solve it...
Here is an attempt for a sketch but I am not sure if its right..
Good - you got the wave-form on the string - now you can write out the wavelength in terms of L.
Notice that one wavelength fits 2/3rds of the string...
On the same diagram, you can sketch in the pressure wave for the can.
The point of the problem is to exercise your understanding. You get a lot of these puzzle-type things before you can be turned loose on a real example.
Hello sir, thank you for your help I appreciate it.
I wrote out the wavelength in terms of L for both can and string and I tried to write the mathematical relationship using it, is that correct?
I think I made a mistake in the calculation in Vt/L = 3/2 Va/ L/15
In your original equation you had a 4. Now you have L = ##\lambda_c##.
What is the wavelength that matches the fundamental frequency of the can ?
I'm not even sure if my original equation is correct. I though at the beginning that the string will act with a frequency for a tube with one open end and one closed end that's why I had a 4. For the wavelength of the can I used L=λc
Well, to me the description and your drawing look a lot like "a tube with one open end and one closed end" ! :smile:
Thanks for the help I appreciate it. If I understand its right so the can is actually going to have a frequency of Fn = nv/4L and the string is going to have a frequency of f=V/λ
Do distinguish ##\lambda_{string} = {2\over 3} \; {L\over 10}## and ##\lambda_{can} = ## ...
And: do distinguish ##v_{string}## and ##v_{can}##.
What is equal is the tone, i.e. the ...
4L? because the can has a frequency of f1 and the string is going to have a frequency of f3
Simon Bridge said that I can sketch in the pressure wave for the can what does he mean by pressure wave?
If you prefer, sketch the logitudinal wave along the can.
The wave in the can is a sound wave in air... i.e. a wave of variations in air pressure.
You have notes that show the harmonics in a tube that is open at one end.
You can reason it out ... in the logitudinal wave, the air particles move the most at antinodes, and the least at nodes, where do those have to be? You are also told that the wave is the fundamental.
This way of reasoning through the physics is more reliable than trying to remember the right equation.
I got that the wavelength of the string is 2/3 (L/10) and the wavelength of the can is 4L is that correct?
Some notes... when you wrote. $$\lambda_s =\frac{2}{3}L=\frac{2}{3} \frac{L}{10}$$... that was nonsense. Can you see why?
You keep making that kind of mistake... it will cost you marks.
It is very important that you figure it out.
Unfortunately, I am very confused. Physics is not my strength. This problem is very important for me
Can you explain how those should be correct? Reasoning is more important than being right.
The point of getting you to sketch things out is so you won't need to ask if its correct, there will only be one possibility.
I thought the the wavelength of the string is the diameter of the can. If the string has a 3rd harmonic frequency and its an open pipe I though using the equation λs=2/3L. For L I used the diameter of the can because its the length.
The mistake you keep making is actually maths, not physics. Take another look, what is wrong with the equation?
λs=2/3L=2/3 L/10 Its going to be 2L/30 which is L/15
... however L is defined in the problem to be the length of the can, not it's diameter.
In fact, you used it for both things in your maths. This is not allowed, different things have to have different symbols.
Ok so the equation is going to be λs=2/3Ls
... where Ls is the length of the string... and Ls = L/10. See how that works?
Personally Id have used D for diameter but only because I hate subscripts.
Is L/10 considered as the wavelength of the string too?
No. You seem to be having trouble understanding what equations are saying.
Ls says "the length of the string"
L says "the length of the can"
Ls = L/10 says "the length of the string is the length of the can divided by 10"
You already have an equation that says "the wavelength on the string is two-thirds the length of the string".
So I understand that the wavelength of the string is length of the can (L) divided by 15 is that right?
I got 15 from plugging L/10 for Ls in the equation λs=2/3Ls
Well done.
Basically you ended up with the same answer, but, this time, you arrived using clear maths.
How you get there is more important than the destination.
Now you need to relate what you know about the wavelengths to the va and vt values you are asked to find.
Ok Thanks for the help! I appreciate it :smile:
