How does the circuit in a stun gun produce high DC voltage
Stun guns and fly swatters utilize circuits that can significantly increase the voltage from a standard 9-volt battery, typically employing boost or flyback circuits. These circuits are designed to step up the voltage to levels necessary for their operation, often reaching thousands of volts. The flyback circuit is commonly used in older CRT TVs to generate high voltages, and similar principles apply to devices like tasers and fly zappers. While discussing such circuits, caution is emphasized due to the potential dangers associated with high voltages. Understanding these components is essential for electrical engineering students interested in practical applications.
Gabe P.
How does a stun gun or a fly swatter circuit produce DC voltages that are at least 2 or 3 orders of magnitude higher than the single 9 volt DC battery used to power the device. I would appreaciate if someone can give me some information regarding the sort of components/circuits that are used to raise the batery voltage to these large levels.
P.S. I'm an electrical engineering student and have already taken the electronics I course.
hi Gabe
welcome to PF :)
we try and avoid talking about weapons like that here ... don't want to give bad people ideas on how to hurt other people
The net is full of circuits ... do a google search
cheers
Dave
it's not for weapon purposes i was just looking at my fly swatter carefully and started wondering how it worked. If a fly swatter is a weapon then i guess i must be living in another dimension. Just mentioned the stun gun because it's a prime example.
Welcome to the PF, Gabe.
We get a lot of newbies here who want to build their first electronics project, and it often involves high voltages that are dangerous if not treated correctly. That's why we are a little careful about discussing such circuits and applications.
But to answer your question, you can use either a "boost" circuit, or a "flyback" circuit to step up a source voltage. I prefer to start with a Google Images search for such circuits, since that gives me a better selection to click into to learn more. The flyback circuit is what is used in your (old style) CRT TV to make the 25kV anode voltage for the screen. I'd guess that the fly zapper and Taser use a similar circuit.
Thank you very much.
Disposable cameras have a flyback converter for the flash. Most photolabs will give you a grocery sack of them for free.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
