How Does the Weight of a Pendulum Affect Its Motion?
The discussion revolves around the motion of a pendulum, specifically examining how the weight of the pendulum affects its motion and period. Participants explore the relationship between mass, gravitational force, and oscillation characteristics in the context of a pendulum system.
  • Participants question the role of mass in the pendulum's motion, with some referencing the formula for the period of a pendulum that does not include mass. Others discuss the effects of changing mass on the period and the implications of liquid dynamics within the pendulum setup.
The conversation is ongoing, with various interpretations of how mass influences the pendulum's motion being explored. Some participants have provided insights into the physics principles involved, while others are seeking clarification on specific aspects of the problem.
Participants are considering the effects of air resistance and the dynamics of a pendulum containing liquid, which introduces additional variables that may affect the period. There is also a mention of the educational context, with one participant indicating they are self-studying physics at a specific level.
gapgirl1010
Could someone please explian the motion of a pendulum for me? When the weight is heavier is the pendulum slower or fast than when the weight is less?
Could you brief a bit more on your current physics background or at what level are you studying harmonic motion.
The equation for the period of a pendulum is
[tex]T = 2\pi \sqrt{\frac{L}{g}}[/tex]
where L is the length of the pendulum and g is the gravitational constant. As you can see, there is no mass in the equation.
I am teaching myself Physics 20. the question is basically that you tie a cococnut to a string and put a hole of the cocnut at the bottom so that the milk flows gradually out.
The question is asking what variables affect the period of the penduallum
A screw is put into the top of a cocnut and a long string is tied to the cocounut to make a simple penullum. A small hole is punched into the bottom of the coconut and the pendulum is made to oscillate. The cocnut milk flows gradually out through the hole. It is observed that the period gradually increases at first and then gradually decrease to its initial value. Explain why the period of the pendulum changes in this way.
As mass in the pendulum decreases, so does the force of gravity on it. So while it can now move faster due to less inertial resistance, there is less force making it move. The trade off is just enough so that mass doesn't affect the speed of the pendulum. Only the variables mentioned will.
Edit: Are effects of air resistance involved?
I don't know
part A askes Which variable(s) affect the period of the pendulum
As the Earth doesn't care how massive an object is when one leaves two bodies with different masses they fall with the same g=9.81
meter/second.second.
so is with a pendulum as they release from their maximum height ,they won't become affected by their masses.
But if you connect some mass with a spring and
you make a mass-spring system ,the mass does
influence the motion of the spring.For a large mass the vibration of the spring becomes slower.So one may find the value of a mass on some planet by a mass-spring system .
One can measure the g-value for an unknown planet through a pendulum.
much luck
there is more tension in the string while the coconut contains liquid, Tension = W = mg
stretching the string, thus increasing L, increasing T
the swaying of the liquid (momentum; mv) inside the coconut will add a marginal horizontal force pushing the coconut higher and decreasing the frequency (f = 1 / T) of oscillation.
thus increasing T
  • · Replies 23 ·
