How does this affect the length contraction paradox?
67 replies · 10K views
DaleSpam said:
The MCIF is the inertial frame where the object is momentarily at rest. This is another completely standard definition.
That still leaves the 'inertial frame' to be defined.
DaleSpam said:
Relative acceleration between reference frames is not reciprocal. Consider a rotating observer and an inertial observer at rest relative to the COM of the rotation. The rotating observer assigns a large coordinate acceleration to the inertial observer, but not vice versa.
Sorry, I don't see your point. Can you elaborate?
Fantasist said:
So you think it is useful if, on the basis of your 'accelerator' reading, you believe your rocket is on its way to the stars, but in reality you may still be sitting firmly on the start ramp?
DaleSpam said:
I don't know why you would think that.
Because of what you said before
DaleSpam said:
In my opinion, proper acceleration is the only physically important acceleration and coordinate acceleration only tells you about your coordinate system and not about the physics.
From which one could conclude that you consider it unimportant whether the proper acceleration of the rocket actually gets you somewhere or not.
Evidently, 'proper acceleration' is based on a purely local physical measurement, but in general it is not the best of ideas to completely ignore the global physics around you.
DaleSpam said:
In the equation t=0 is the moment when the rod is momentarily at rest. So in your example t would start out negative, the rod would slow, and is length would increase, until it reached the peak altitude at t=0.
With the formula as written, that would hardly be an acceptable solution, as it would imply that the observer has to re-synchronize his clock dependent on which rod he measures (or even use different clocks for each rod in the first place). The only thing you could do is to add an initial velocity to the argument A*t i.e.
##x2(t) - x1(t) = (X2-X1)\sqrt{ \left(1- \tanh(At-V0)^2\right)}##
But what about a different scenario? Assume the observer is actually based outside the gravitational field of the Earth (e.g. at one of the Lagrange points) and observes the free-falling rod attracted by the earth. Clearly, both the observer and the rod have zero proper acceleration, so you should not observe any length contraction of the rod, despite the fact that its velocity with regard to the observer increases.
Go get a textbook. Inertial frames, proper acceleration, MCIF, and all the rest of the standard terminology will be defined there along with detailed explanations and example problems.
I don't know why you would conclude that from what I said.
If you know the global metric then you can use proper acceleration to navigate through it. In fact, cruise missiles do exactly that so that they can approach their target even in the absence of any external information.
If you do not know the global metric then you have no reason to believe that any degree of proper acceleration is leading you any closer or further from a given star.
Furthermore, without the metric, knowledge of the coordinate acceleration doesn't tell you if you are getting further away from or closer to a distant star either. So you cannot say that coordinate acceleration is in any way more parsimonious or informative than proper acceleration.
The synchronization was defined from the question in your OP where the rod and observer were at rest at t=0. It seems a little silly to complain about an answer that uses the same convention as your question.
Sure. Rindler coordinates are for flat spacetime only. The spacetime around the Earth is not flat. You would have to use GR, not SR for this scenario.
Textbook definitions don't appear to be sufficient to unambiguously answer questions like whether an electron accelerated in an electric field occupies an inertial reference frame or not (assuming that the charge of the electron is distributed homogeneously within its volume (i.e. the electron does not 'feel' the Coulomb force as the latter acts on all parts of it and no internal stress forces are set up)).
That only works because
1) the external references are programmed into the system in advance
2) it is assumed that the external references don't change
3) any change in proper acceleration is interpreted as a change in coordinate acceleration
Any reference for this? I would have thought that the length contraction due to GR just adds to that of SR (after all that is how it is e.g. for the time dilation of GPS- satellite clocks).
The gravitational length contraction
[tex]dr=ds\sqrt{1-\frac{2GM}{rc^2}}[/tex]
does obviously not contain any velocity dependent terms at all, in fact not even any time dependent terms if you consider a stationary rod on the earth. Yet
##x2(t) - x1(t) = (X2-X1)\sqrt{ \left(1- \tanh(At)^2\right)}##
would predict a change of the length of the stationary rod with time as viewed from outside the gravitational field of the earth.
I do not see how the first effect could negate the second one.
Nonsense. The textbook definitions are unambiguous on topics like this. You appear to disagree with the textbooks, but your disagreement does not indicate any ambiguity whatsoever.
Sure, and the same is true of any navigation based on coordinate acceleration.
This is not true. For example, in Schwarzschild coordinates you can have a change in proper acceleration without any coordinate acceleration for an observer whose r coordinate decreases at a constant rate.
Your stated preference for coordinate acceleration is unreasonable, all of your objections are either flat out wrong, or they apply equally to coordinate acceleration.
Yes. The Wikipedia entry I pointed you to on Rindler coordinates clearly shows the derivation from the flat spacetime metric.
Really? Take the Wikipedia definition:
All inertial frames are in a state of constant, rectilinear motion with respect to one another; an accelerometer moving with any of them would detect zero acceleration.
This is not only ambiguous but even a contradiction in one sentence: if you have two accelerated rockets moving with a constant velocity relatively to each other, they would be inertial systems according to the first part of the sentence, but non-inertial systems according to the second part.
Only that the cruise missile wouldn't have a clue about it. If it sits on the ground and suddenly the local gravitational field increases due to some restructuring in the Earth's crust, it will interprete this as an indication that it is is being lifted upwards with a constant acceleration. In this respect the measured proper acceleration is always ambiguous.
I meant a reference that explicitly gives the equivalent of the flat spacetime length contraction formula
in curved spacetime
You have misinterpreted this ( it is rather inelegant). It means that the necessary and sufficient conditions are 1) constant relative velocity 2) both frames have zero accelerometer reading.
First, Wikipedia isn't a textbook. Second, that statement is not a contradiction. It says that if two frames are inertial then they are in a state of rectilinear motion wrt each other. It does not say that if two frames are in rectilinear motion to each other then they are inertial. Your rockets are therefore not a counterexample.
So what? The same is true of a navigation system based on coordinates. If your map is incorrect or outdated you will have errors in either case. Garbage in, garbage out. It is true, but hardly a problem unique to proper acceleration.
in curved spacetime
Not that I know of. I don't even know of a general definition of length contraction in curved spacetime.
in curved spacetime
Do you mean a velocity dependent contraction or a grvitational length contraction ?
The best we can do is consider two worldlines in curved spacetime that coincide at a point p, and calculate the coordinate transformation that connects the local frames at that point. It turns out that this is the Lorentz transformation . So the length contraction formula is x'1-x'2=γβ(x1-x2).
So you are saying an observer in free-fall in the gravitational field of the Earth and another in space (at rest relatively to the earth) are not inertial (as they don't move with constant velocity relatively to each other)?
The velocity dependent contraction of an object free-falling under gravity but observed from outside the gravitational field.
The presence of a gravitational field changes what constitutes an inertial frame. A freely falling object is locally inertial in a gravitational field but a static object in a gravitational field is obviously not inertial, it is an accelerating frame of reference. A static frame accelerates relative to a local inertial frame i.e. it accelerates according to local accelerometer measurements.
You can't insulate yourself from a gravitational field unless you're in an asymptotically flat space-time and relegated to spatial infinity. Even then, kinematical length contraction is local not global so the kinematical length contraction formula would only make sense between two locally separated observers in the gravitational field.
EDIT: don't confuse local Lorentz contraction i.e. kinematical length contraction (which is velocity dependent) with non-trivial proper lengths for ideal rods/rulers due to the presence of a gravitational field.
OK, but this means the condition "All inertial frames are in a state of constant, rectilinear motion with respect to one another" is in general incorrect. The only working definition seems to be that a comoving accelerometer measures zero acceleration. But this in turn would mean that one can never say by purely theoretical arguments whether a reference frame is inertial or not for a given scenario. It is always an actual experimental measurement necessary.
The theoretical definition of a (locally) inertial frame is simply a frame which has zero proper acceleration; proper acceleration can be defined mathematically and measured experimentally. If the "all inertial frames are in a state of constant, rectilinear motion with respect to one another" statement is unappealing and/or confusing to you then just ignore it. All you need to know is that if a frame has zero proper acceleration then it is (locally) inertial.
Fantasist said:
OK, but this means the condition "ll inertial frames are in a state of constant, rectilinear motion with respect to one another" is in general incorrect. The only working definition seems to be that a comoving accelerometer measures zero acceleration. But this in turn would mean that one can never say by purely theoretical arguments whether a reference frame is inertial or not for a given scenario. It is always an actual experimental measurement necessary.
It's always experimental, even without gravity. If two rockets are both accelerating with profiles such that each measures the other to be at constant relative speed, that does not mean they are inertial. To pick out, in the real world, what is inertial motion, you have to make measurements.
I am not confusing it. The question is why the velocity dependent part should disappear for non-local problems (as other posters here have claimed).
It's not that Lorentz contraction disappears; it just doesn't make any sense mathematically to define Lorentz contraction non-locally in curved space-time.
I think it makes perfect sense to ask whether a co-moving non-local observer sees the same velocity dependence for the length contraction as the local observer or not.
In flat spacetime, yes.
In curved spacetime, not so much. You can't talk about "comoving observers" or the "velocity dependence" observed by these observers until you've defined the relative velocity, and that's not so easy for a remote observer to do in curved space.
In curved spacetime there is no way to uniquely identify co-moving non-local observers from non-co-moving non-local observers. The problem is that parallel transport is path dependent in curved spacetime.
EDIT: as Nugatory said
By the way, I never said that the velocity dependent part disappeared. I said that I don't know what the formula is in curved spacetime, and I said that to calculate it would require GR.
Perhaps you are talking about someone else, but I didn't see anyone else say that either.
If I may add something, the whole argument about proper acceleration sort of misses the point.
If we consider an object moving with x(t) = (1/2) a t^2, such a motion is possible for low t , and impossible for t >= c/a, because it requires superluminal velocity for t >= c/a (or alternatively it's subluminal only for at<c). So it's not a "good" relativistic motion in general, but it's OK for "small t".
For small t, the motion represents the motion of an object moving with a constant coordinate acceleration. While possible in principle for small t, you won't find a lot of discussion in textbooks. In the case where t << a/c, a taylor series expansion of the motion of constant proper acceleration for x(t) will show that it's nearly equivalent to constant coordinate acceleration, as one would expect. In the intermediate range where t < a/c but of the same order, the two motions differ, and when t>=a/c constant coordinate acceleration becomes imposibile because at> c, and noting can move as fast or faster than light.
The errors in the first post were in not applying relativity properly.
You start with a single x(t), representing the motion of an observer.
There isn't, at this point, any x1(t), or x2(t). There is only x(t), the motion of "the observer".
You then need to define "the coordinates" of an accelerated observer" SR has a prescription for this, based on using the momentarily co-moving inertial frame. The notion does not extend gracefully to GR. The notion has a well-known weakness even in SR regarding the uniquness of the coordinates that I'll mention but gloss over, because it would be too confusing to explain at this point to the OP and not really relevant to the point.
Given the worldlines x1(t) = constant and x2(t) = constant, the wordlines in the momentarily comoving inertial frame can be defined using the Lorentz transform.
You wind up with different coordinates X1(T) and X2(T), where T represents the transformed t coordinate, and X1 and X2 represent the transformed x1 and x2 coordinates.
The error in the original post (#1) in my opinion was in not applying the Lorentz transform, but using the Galilean transform
i.e. it used
X = x - vt
T = t
rather than
X = x - vt
T = t- vx/c^2
and it skipped a few important steps by assuming that the Gallilean transform was correct.
The lorentz transform is one of the basics of special relativity. http://en.wikipedia.org/wiki/Lorentz_transformation
So post #1 basically did a non-relativistic treatment of the problem. I'm afraid I don't really have the time to do a full treatment of the problem correctly, and I think trying to do this in a post for someone not already familiar with relativity is a bad idea. If they are motivated enough, they can find a textbook. One can hope that this discussion will so motivate them, it's probalby not practical to learn SR from reading posts to a forum.
I'd also like to encourage the OP to avoid trying to hammer everything into the "observer" framework if this is at all possible. I'm not sure how successful I'll be at that. It sounds like they have not realized that "observers" aren't really required or all that useful, and they would most likely proceed to defend and cling to the notion :( rather than think about alternatives to observers - which , to put it succinctly are generalized coordinates.
There isn't really any transport involved for determining the velocity:
if you consider a triangle on a sphere, the cosine rule gives you
cos(c) = cos(a)*cos(b) + sin(a)*sin(b)*cos(C)
Now if you choose c infinitesimally small (c=dx) and the other sides equal (b=a), this becomes
cos(dx) = cos2(a) + sin2(a)*cos(dC)
and if you expand this in a Taylor series
1-dx2/2 = 1-sin2(a) + sin2(a)*(1-dC2/2)
or
dx2 = sin2(a)*dC2
i.e.
dx = dC*sin(a)
or with dx=v*dt
v = dC*sin(a)/dt (sphere)
where dC is the observed angular change of position during time dt.
Now in flat geometry, the cosine rule is
c2 = a2 + b2 -2ab*cos(C),
so with the same definitions as above we get
dx2 = 2a2 - 2a2*(1-dC2/2)
i.e.
dx = a*dC
or
v = dC*a/dt. (flat)
If you compare the two expressions for the curved and flat geometry, it is evident that the derived velocity dependence is the same apart from a constant factor (sin(a) instead of a) associated with the different metric.
So a co-moving observer (v=0) in flat space is also a co-moving observer in curved space.
