How does this affect the length contraction paradox?
67 replies · 10K views · last reply
pervect said:
If I may add something, the whole argument about proper acceleration sort of misses the point.
If we consider an object moving with x(t) = (1/2) a t^2, such a motion is possible for low t , and impossible for t >= c/a, because it requires superluminal velocity for t >= c/a (or alternatively it's subluminal only for at<c). So it's not a "good" relativistic motion in general, but it's OK for "small t".
For small t, the motion represents the motion of an object moving with a constant coordinate acceleration. While possible in principle for small t, you won't find a lot of discussion in textbooks. In the case where t << a/c, a taylor series expansion of the motion of constant proper acceleration for x(t) will show that it's nearly equivalent to constant coordinate acceleration, as one would expect. In the intermediate range where t < a/c but of the same order, the two motions differ, and when t>=a/c constant coordinate acceleration becomes imposibile because at> c, and noting can move as fast or faster than light.
The errors in the first post were in not applying relativity properly.
I mentioned already earlier (post #27) that the assumption of a constant acceleration was only done for convenience. It is not material for the argument. One might as well have a time dependent acceleration for which the coordinates would then change according to
x1(t) = x1(0) - [itex]\Delta X(t)[/itex]
x2(t) = x2(0) - [itex]\Delta X(t)[/itex]
where
[tex]\Delta X(t) = \int_0^t dt' \int_0^{t'} dt'' a(t'')[/tex]
pervect said:
You start with a single x(t), representing the motion of an observer.
There isn't, at this point, any x1(t), or x2(t). There is only x(t), the motion of "the observer".
Sorry, I don't get your argument: if you want to measure the length or distance of something you have to measure by definition the coordinates of two points x1 and x2. The length/distance is the difference of the two coordinates i.e. L=x2-x1. If you have e.g. a ruler free-falling past a very tall building with two markings on it, then the ruler coordinates of these markings give you the distance between them in the reference frame of the ruler (L(t)=x2(t)-x1(t)).
pervect said:
Given the worldlines x1(t) = constant and x2(t) = constant, the wordlines in the momentarily comoving inertial frame can be defined using the Lorentz transform.
You wind up with different coordinates X1(T) and X2(T), where T represents the transformed t coordinate, and X1 and X2 represent the transformed x1 and x2 coordinates.
The error in the original post (#1) in my opinion was in not applying the Lorentz transform, but using the Galilean transform
i.e. it used
X = x - vt
T = t
rather than
X = x - vt
T = t- vx/c^2
and it skipped a few important steps by assuming that the Gallilean transform was correct.
A length measurement implies by definition that the two coordinates are determined simultaneously. If you Lorentz-transform the coordinates of such a length measurement to a different reference frame, then this does not constitute a length measurement in the latter frame anymore. You need an independent measurement where the two coordinates are determined simultaneously in this frame as well.
Since you're so adamant about this without giving any textbook references regarding the well-definition of non-local 3-velocity measurements that you so stubbornly cling to, tell me mathematically and physically how a static observer at some ##R >> 2M## in Schwarzschild space-time would make an unambiguous measurement of the 3-velocity of an observer falling in from infinity radially when the infalling observer is at some ##r = 2M(1 + \epsilon)## where ##\epsilon << 1##. I assure you that if you don't know the basics of differential geometry, you will find this futile.
Just to give you some background, if an observer has 4-velocity ##\xi^{\mu}## and another observer has 4-velocity ##\eta^{\mu}## then ##\xi^{\mu}\eta_{\mu}## is only defined when the two observer's worldlines intersect (i.e. they meet at an event coincident on both their worldlines) because in curved space-time you can only take the "inner product" of two 4-vectors when they both lie in the same tangent space to the space-time manifold (that is to say ##\xi^{\mu}\eta_{\mu}## is only defined if ##\xi^{\mu}## and ##\eta^{\mu}## are in the same tangent space to the space-time manifold at a given event). The relevance of this is that a 3-velocity measurement of ##\eta^{\mu}## by ##\xi^{\mu}## at a coincident event on both their worldlines is mathematically given by ##\xi^{\mu}\eta_{\mu} = -\frac{1}{\sqrt{1 - v^2}}##.
EDIT: And seriously, start reading textbooks on SR and GR. Forum threads can only do so much for you.
Fantasist said:
There isn't really any transport involved for determining the velocity
Yes, there is. See chapter 3 here:
http://arxiv.org/abs/gr-qc/9712019
e.g. "two particles at different points on a curved manifold do not have any well-defined notion of relative velocity — the concept simply makes no sense" (p. 64)
where
If you have a non-uniform acceleration then there is no standard definition of the non inertial observers coordinate chart. There are several different options. My favorite definition is the Radar Coordinates used by Dolby and Gull:
http://arxiv.org/abs/gr-qc/0104077
That should be only the case if you leave the path undefined. However, any physical measurement will automatically define an unambiguous and unique path. In this case, if you observe the motion and length of the rod (located in the gravitational field of the earth) through the eyepiece of a telescope from outside the gravitational field, the path is clearly defined by the corresponding light path connecting the rod and the observer. I have shown above (post #60) what the latter would derive for the velocity in case of a spherical metric. It may be a bit more difficult in case of other metrics, but should still be straightforward as long as you know the curvature along the light path. In any case, for sufficiently small displacements of the rod (so that locality is preserved) and a stationary gravitational field, the observed velocity dependence of the length contraction should be independent of the metric.
The fundamental difference is that with no gravity, there is no path dependence. You can say there is a comparison between distant vectors with no further qualification. In the presence of gravity, you have to specify a procedure - and different procedures yield different results.
What happens if between you and a ruler is a compact gravitating body of great mass. Then, your image of a ruler through a telescope will be a ring with struts coming out of it.
Yes. If you specify a path you can have a well defined comparison between different vectors, and a physical measurement would definitely have a unique result.
Yes, that is certainly a measurement which could be analyzed. However, such a measurement is unrelated to length contraction. I.e. Such a measurement would not result in length contraction in flat spacetime.
No you didn't. I don't know why you would think you had.
Locally I agree. Non-locally you would have to do an in depth analysis using GR and a detailed experimental measure.
Then let's not argue about it. The point that I think is relevant is that "acceleration" is ambiguous, you need to specify whether and when you are talking about coordinate acceleration and when you are talking about proper acceleration.
You haven't really disambiguated your text, so I'm not sure if the point has gotten through or not, or if you actually understand the distinction :-(.
The point is peripheral, but it could help you to understand the main issue. Since it is peripheral I won't go into more detail.
I agree, and the two points in question are X1 and X2, so there isn't any disagreement with how you calculate distance.
The difference between X1 and x1 is a matter of notation. I had reasons for using my notation, it's just a matter of consistently applying the Lorentz transform.
What is really important, and not just a matter of notation, is that x1 is a function of t, while X1 is a function of T.
The difference between t and T is *not* just a mater of semantics. What is represented by the symbol t is not the same thing that is represented by the symbol T.
I suspect that you are entrenched in the notion of absolute time, which is why you use only one symbol for time, "t", for all observers, rather than distinguishing between t and T.
