How Does Thrust to Weight Ratio Impact Engine Efficiency?
  • Thread starter Thread starter chhitiz
    Design
The forum discussion centers on the impact of thrust-to-weight ratio (T/W) on engine efficiency, specifically regarding a proposed toroidal internal combustion (IC) engine design. Participants highlight challenges such as sealing issues, torque generation, and the need for effective fuel and exhaust management. The conversation emphasizes the importance of calculating efficiency, with suggestions to utilize software like Abaqus for stress analysis and to consider existing patents on similar designs. Overall, the discussion reveals that while the concept is intriguing, significant engineering challenges remain to be addressed.
  • Understanding of internal combustion engine mechanics
  • Familiarity with thrust-to-weight ratio (T/W) concepts
  • Knowledge of thermodynamic cycles and efficiency calculations
  • Experience with CAD software such as Catia or Abaqus for simulations
  • Research existing patents on toroidal engine designs
  • Learn how to perform stress analysis using Abaqus
  • Study the Otto cycle and its application to engine efficiency
  • Explore methods for calculating the efficiency of new engine designs
Engineers, automotive designers, and researchers interested in innovative engine designs and efficiency optimization will benefit from this discussion.
  • #31
i think you have confused mechanical design with an idea. there are no calculations or measurements provided. Perhaps if you can draft the pictures out or use CAD and provide some of the formulas etc , then people can better assess how workable this project may be.
  • #32
@ grey it is not otto cycle.more like a three stroke cycle.
@ bystander yes, but we can't use gas turbines in automobiles. for one thing, they operate at very high temperatures and pressures
@ blade well, I'm trying to, but could people anyways suggest a way to calculate efficiency or something
  • #33
It looks like you made that in Abaqus (?). If so, did you run an FE simulation to see what types of stresses are in the engine? One of the biggest concerns in efficiency is thrust to weight ratio (T/W). If you want to take this to the next step, I recommend seeing what your stresses are like, and determining if you have too much / too little material. Factors of safety are also important.
  • #34
I didn't see anything.
  • #35
chhitiz said:
... guide me as to how to calculate, at least in theory the efficiency ...
chhitiz said:
... can we simply guess the efficiency based on c.r.? is there a way to calculate the precise efficiency of a completely new design?
chhitiz said:
... could people anyways suggest a way to calculate efficiency or something ...
What exactly do you mean by 'efficiency'? Can you write down what you mean in words, and then take a stab and quantifying it? Why do you think calculating it is any different then the 'efficiency' calculations described in the automotive engineering textbooks?
  • #36
it was made in catia. and as far as i know, there is no way of getting the stresses in it.
efficiency is how much of the chemical energy of the fuel is actually converted into useful work. and calculating it is different because this design will have a totally different thermodynamic cycle
  • · Replies 25 ·
  • · Replies 16 ·
