Clumping as it happens in our universe is a small effect - even for the largest scales, superclusters, the solid angle coverage of the stars is small compared to their size in the sky, so overlap within a cluster is rare.
The real star density is even lower than assumed in the first post - okay, this is partially canceled by some very large stars.@FactChecker: We don't live in 2 dimensions, you need the squared radius and star spacing.
Assume every (10 ly)^3 cube has one star (a random distribution gives the same result). A light ray (or imaginary "sight ray"), going through this cube, has a chance of ##\frac{pi r^2}{(10ly)^2}## to hit the star with the radius r. Therefore, as expectation value, we have to go through ##\frac{(10ly)^2}{pi r^2}## cubes, for a distance of ##\frac{(10ly)^3}{pi r^2}##. Plugging in the solar radius, this gives 59*10
15 light years. This is still way beyond the observable universe.
The large difference to Matterwave is the difference between the expectation value (this post) and the maximal distance (Matterwave's calculation). The overlap is just a factor of ~2.
@StrangeCoin: The stars in those image are all smaller than a pixel - you just see the finite resolution of the telescope.
Dr J L said:
I'm just here to learn. But learning start from perception within any mathematical equation on earth. If you were say on the moon or any where that does not have gravitational, pull then the perception would be different. Perception starts at any stand point, doesn't matter if on the ground or on Mars or on the moon. The variables will always be different unless in a double blind study. Plus when you are in water the perception will be different because the gravitational pull is different.
Sorry, but that does not make any sense. Gravity is not relevant here. And gravity does not change if you are in water.
