How fast could the person have to travel?
  • Thread starter Thread starter jenita
    Travel
The discussion revolves around a relativistic mass increase problem where a person with a mass of 48 kg wishes to gain an additional 12 kg in a different reference frame. Participants are exploring how to calculate the necessary speed to achieve this mass increase using relativistic equations.
  • Mixed
  • Participants are attempting to clarify the definitions of the variables involved, particularly distinguishing between the rest mass and the relativistic mass. There are questions about the correct use of the relativistic mass equation and how to rearrange it to solve for velocity.
The discussion is ongoing, with participants providing various interpretations of the mass values and the formula. Some guidance has been offered regarding the rearrangement of the equation to isolate the velocity, but there is still confusion and lack of consensus on the calculations and the correct approach.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also a noted misunderstanding regarding the speed of light and its representation in calculations.
jenita
a person whose mass is 48 kg wishes to gain 12 kg relativistically with respect to another reference frame. How fast could the person have to travel?
the formula is as follows...
i Think M is 48 kg
mo is 12 kg
v=? can anyone help me to do this problem
Mo will be 48 kg. M will not be 12 kg, since the question states that the person wishes to gain 12 kg (so the mass will increase by this much).
I can't see the picture yet. Does it show where you are getting stuck?
sorry i don't no why the pic is not showing up...its the formula in the pic... i hope u no the formula...if mo is 48 then what is 12kg
is 12 kg M or do we have to find M first
oh you by the way c is 3.8 * 10^8
is the answer 75000000
Is this the equation you have?
[tex]M = \frac{M_o}{\sqrt{1 - v^2/c^2}}[/tex]
You want to solve for v. Don't worry about the actual value of c (you've got it wrong by the way, it's 3x10^8 m/s), just leave it as "c" in your work. At the end, you can worry about converting it.
You are given Mo. You can figure out M because you know the gain in mass is 12 kg. So, what is M, then?
but to find M don't u need V
Please show how you got that answer.
how can i solve it if i don't have M, v, and c...dont i need to have 1
You are trying to solve for v. You must rearrange that equation to get v in terms of the masses. It IS the equation you are using, right?
You have the information to get both masses without solving anything!
75000000...i got this by inserting 12 for M, 48 for mo and 3.08*10^8 for c...
i divided 12 from 48 which i got.25 and the squared it and got.0625... i squared 1 and c and then multiplied by c and 1 to the .0625... i was left with 5.625e15=v^2 and i squared it and got the answer... sorry it looks confusing
and yes that is the equation we are using
Like I've already said, M is not 12 kg. 12 kg is the change in the mass. So if the mass started at 48 kg and 12 kg is added relativistically, what is the new mass (M)?
oh lol...its 60 kg
so u insert 60 for m
so for M u insert 60 and then solve
jenita said:
oh lol...its 60 kg
There you go! Let's see what answer you get now.
i got 375000000...i did the same way like i did to get 75000000
Well that can't be right since that is faster than the speed of light. Are you using 3 x 10^8 m/s for c?
yes i am using that
Then you've gone wrong in the algebra somewhere. Can you show me your expression for v after rearranging that equation?
60/48=1.25 1.25^2== 1.5625 and then multiply with c^2 and i got 1.40625e17=v^2
and then did the square root on both sides and got that answer
No, that's not right.
Original equation [tex]M = \frac{M_o}{\sqrt{1 - v^2/c^2}}[/tex]
To get v you should start by doing this (cross multiply):
[tex]\sqrt{1 - v^2/c^2} = \frac{M_o}{M}[/tex]
Does that help point you in the right direction?
Don't mix up M and Mo.
i know this is stupid question...i just came across...do break the square root u have to square it then its (v2/c2) ^2..isnt it
i got 240000000
can u check in the calculator if that is right or not
i kinda did check answer by replacing .64 for V i got 62.47 for M
omg ignore this
  • · Replies 236 ·
18K
  • · Replies 65 ·
15K
  • · Replies 125 ·
  • · Replies 36 ·
12K
