How fast does a hydraulic machine work?
The speed of a hydraulic machine is primarily determined by the flow rate of the fluid within the system. For a two-sided setup with different surface areas, the speed of movement is not instantaneous and can vary based on the flow rate needed to fill the cylinder's volume as it extends. The diameter of the connecting tube significantly impacts the system's performance; a smaller tube requires higher pressure to achieve the desired flow rate. Additionally, the discussion highlights the importance of precise questions for clearer answers. Understanding these factors is crucial for optimizing hydraulic machine efficiency.
robhlee
How fast does a hydraulic machine work? The model i am thinking of is a simple two-sided setup, where the surface areas of the two platforms are different and a tube connects them. In terms of movement of the two platforms, how fast can the machine work. I am just looking for an approximation, like can it be instantaneous or are hydraulic machines usually very slow-moving?
Also, would the diameter of the tube connecting them (smaller than the diameter/surface area of either platform) affect the speed of the mechanism?
Robhlee, when I suggested that you have this moved to Engineering, I didn't mean for you to repost it. A mentor can relocate the complete thread for you.
In theory, the speed limiting factor of any hydraulic system is going to be the flow rate of the fluid. If you want a cylinder to extend at a certain rate, you need to have a flow rate that will fill that cylinder's volume as it is extending that fast. So to answer your question about the tube size having an effect, I would say that it depends. You need to create enough pressure in the system to provide the flow you need. If you have a very small tube, you need a pretty high pressure.
Your other questions are pretty vague. They are difficult, if not impossible to answer. Can you be more precise with what you want to know?
how can i show a picture on this forum (w/o creating a new topic) ?
You have to add it as an attachment. When you post, look for the "Go Advanced" button. When you press that a new post dialog will come up. One of the options below that is to "Manage Attachments." Use that to attach a picture or any other file that is on the list of approved attachments.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
