How Fast is the Man Walking as His Shadow Changes?
erix335
A man 6 feet tall walks away from a streetlight that is 18 feet tall. If the length of his shadow is changing at a rate of 3 feet per second when he is 25 feet away from the base of the light, how fast is he walking away from the light at this moment?
Trying to figure it out.
Diagram drawn to no avail.
hi erix335
consider the triangle made by the shadow tip and the street light
and then the triangle made by the shadow tip and the man
you should be able to see they are similar triangles
use this to try and write the length of the shadow, s, as a function of the distance, d, the man is from the pole s(d)=?.
once you have that you differentiate to find the rate of change
2s(ds/dt)= (25-3t)^2 + ?(18-6t)^2
2(30.8 hyp of triangle) = 2(25-3t)3+2*18-6t)6
61.4=(50-6t)3+(36-12t)6
=366-90t
-304.6/-90=t
t=304.6/90 or 3.38...which seems to be a right answer but the second part of my equation had no real thought behind it.
I seem to be stuck in the initial equation, and the 3.38 is the value of t, which means I would have to put it under 25, giving me a bit of a ridiculous answer.
=366-90t
-304.6/-90=t
sorry i can't understand what you have done, can you explain it?
took the derivative of the speed and hypotenuse equation...or so I thought, then filled in for T and put it under the distance (25)
what was the hypotenuse equation?
i would start by finding s(x), as a function of the distance the man is from the pole
s = shadow length
x = distance of man from pole (sorry, had to change d=x for noatation in the derivative, otherwise it was too hard to read)
then using the chain rule
\frac{ds}{dt}= \frac{ds}{dx}\frac{dx}{dt}
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
