How is Angular Momentum Conserved in a System Without External Forces?
2 replies · 2K views
vivinisaac
angular momentum trouble!
since the angular momentum of a particle moving about a fixed point (axis) is given by
L=r X p= r X mv
where;
L=angular momentum
r= distance from the axis
p=linear momentum of the particle
m= mass of the particle
v= linear velocity of the particle
but if the distance 'r' decreases linear velocity 'v' should increase due to the law of conservation of angular momentum
but if linear velocity 'v' of the particle decreases then the linear momentum 'p' would also decrease , but this is against the law of conservation of linear momentum.(there is no external force acting on the system)
how is this possible .pls explain
there r no external force acting on the system including torque (friction is neglected)
eg. a planet revolving around the sun,as it comes closer to the sun its linear velocity increases bcuz angular momentum must be conserved but the increase in velocity means that its linear momentum wud increase
Please give a specific example of what you're talking about. Angular momentum is only conserved in the absence of external torques; linear momentum is conserved only in the absence of external forces.
In this case the system is "sun + planet". Neither the angular or linear momentum of the system changes. Of course, the planet's linear momentum changes as it nears the sun, but so does the sun's linear momentum; those changes are equal and opposite.
