How Is Energy Lost in a Resistanceless System?
  • Context: Graduate
  • Thread starter Thread starter VishalChauhan
    Energy
10 replies · 2K views
VishalChauhan
Say, i have two concentric shells,each carrying a different charge.If i connect an ideal, resistance less wire between the two, charges will flow till potential of the two shells is equal.For an arbitrary selection of charges, the final and initial energy is not same(try it with two shells of radius r and 2r, with the inner one charged initially). Since the connecting wire is resistanceless, it does not cause any loss of energy.
Where does did my energy go?
No, it will continue to flow until the initial potential energy is reached. Than the charges will flow backward and the process starts again. During this oscillation the total energy remains constant.
That is quite contrary to what i have read.The only "motivation" for charges to flow will be a potential difference, and once that does not exist,there should be no flow of current.
Have you read about inductance?
How are you calculating the energy of the system..
VishalChauhan said:
Yes.
Then you have your answer. The setup you described has non-zero inductance, so as the current flows a magnetic field forms; as the potential difference is reduced the magnetic field collapses generating an induced voltage which continues to drive the current even after the potential difference has fallen to zero. Then when the magnetic field is completely collapsed, the two previously low-potential shell will be at a higher potential and the cycle will repeat in the other direction.
You've just built an capacitor/inductor oscillating circuit - google will find you plenty more explanations.
And the answer to your question "where does the energy go" is that it goes into the magnetic field, and then back into potential energy to drive the next cycle of the oscillation.
I am making a guess here, but ultimately these oscillations would damp out.Would then, the final energy loss be due to radiations?
In any real system, the resistance of the wire won't be quite exactly zero, so most of the energy will end up as resistive heating of the wire. But if you really could build something with zero resistance... yes, the energy loss would be due to radiation.
