Are Photons Reflected Directly from Surfaces or Re-emitted by Atoms?
Photons are primarily reflected from surfaces like mirrors without being captured and re-emitted by atoms, as this would lead to random direction changes. The wave nature of light provides a clearer understanding of reflection, particularly through phenomena like diffraction gratings, which demonstrate that reflection involves interactions with multiple atoms across the entire surface rather than a single atom. The typical behavior of light upon reflection, such as the angle of incidence equaling the angle of reflection, supports the idea that solid surfaces reflect photons directly. Additionally, the presence of conduction electrons in metals plays a significant role in this optical process, enhancing reflection compared to dielectrics. Overall, the discussion emphasizes that while reflection mechanisms can vary, the fundamental principles governing mirror reflection remain consistent.
JR Wakefield
Simple question. Are photons reflected as is from a surface like a mirror, or is the reflecting surface atoms capturing the photons and re-emitting them?
Science news on Phys.org
Certainly not capturing and re-emitting in the sense of electrons changing energy levels. In that process, the new direction would be random.
Reflection is more easily envisioned with the wave nature of light.
Likes FactChecker, davenn and gneill
There are surfaces called diffraction gratings. They can cause photons to reflect at an angle different from the angle of incidence. They are used to show that reflection is not an interaction of a photon with a single atom, but with the entire surface. The photon doesn’t just take one path and interact with the one atom at the apex of that one path. The photon takes all of the possible paths and interacts with all of the atoms in a way that cannot be identified with any single atom of the diffraction grating.
Likes sophiecentaur and FactChecker
But how can we know that this is the same mechanism as reflection from a mirror?
A diffraction grating is just a mirror with blacked out stripes. The same laws of QED that describe the behavior of a diffraction grating also describe the behavior of a mirror without the black stripes.
Likes sophiecentaur
Ok.
It is always problematic if you take a solid, but then start to consider its behavior in terms of the individual atoms. This is why solid state physics is different than atomic physics. There are no energy bands in an atom, but there are such bands in a solid.
There are several things to consider in the typical specular reflection of visible light off a typical mirror:
1. Angle of incidence = angle of reflection
2. There is a π phase shift of the reflected light
3. The "reflector", i.e. the mirror, is typically a smooth metal surface. A dielectric does not make a very good mirror.
Here's what we know:
1. An atom that absorbs a photon and then re-emits it, typically will not re-emit in a specific direction. So accounting for "angle of incidence = angle of reflection" will be extremely difficult. So that explanation that it is due to surface atoms absorbing and re-emitting is not very plausible.
2. Metals have conduction electrons, as opposed to dielectric/insulator. They should play a role in this optical process (and they do).
Zz.
Likes Dale and sophiecentaur
Or a mirror with a “sawtooth” profile.
Likes Dale
Thanks to all for replying. I already knew the answer. But simple things like your reflection in a window, or the road reflection off the asphalt at very low angles, and even prisms, shows photons bounce off surfaces.
Are you referring to the mirage produced by the thermal gradient of the air?
You started off by asking for a smple reflection off a mirror! Now you're changing the parameters.
I didn't say that ALL types of reflection are governed by the same process. The case for Bragg reflection off crystal lattice planes has already been mentioned. You asked for a specific case, you got a specific answer relevant to that case. It was not meant to be used where it doesn't apply.
Zz.
Likes Daemon9 and Dale
