How is reductio ad absurdum a valid proof method?
  • Level: Graduate
  • Thread starter Thread starter Werg22
    Method Proof
41 replies · 15K views
peos69 said:
If for example the real Nos system is not consistent then nature itself is not consistent
I'm not even sure what it would mean for nature to be inconsistent. In a formal system it means that there is a proposition P such that both P and not-P can be proved. Any inconsistent system containing classical first-order logic can, in fact, prove any statement. But what would the analogue for 'nature' be?
Suppose you let a mas m fall from the top of the building of height, h, then you can prove the following proposition P.
FOR all m and for all h [ if air resistance is 0 then the time taken for m to reach the ground will be, t=sqroot(2h/g)].
Now the negation of this P WOULD be that there exist an m and an h such that t=/=sqroot(2h/g),where g =10m/sec^2,provided of course that again air resistance is 0.
Here is your analogue
How? This is, for sure, a theorem of Newtonian mechanics, but how can you prove it for 'nature itself'?
I am not sure i get you point please be a bit more specific
I think Hurkyl is asking 'what does it mean for Nature to "prove" something?'.
you are inside your apartment and you ask your friend.How long do you thing it will take if i jump from the top of the Empire Building?your friend takes out his pencil and he does a few calculations and he tells you the time.Then you go to the top of the building,you set your watch,you jump and when you land on the ground you check your watch.If the time is the same with the time calculated by your friend then nature has |"proved" the Newtonian theorem in mechanics,which your friend used to find out the time.
No, it hasn't. Newton's laws are not mathematical theorems. They are scientific theories. Mathematic theorems and scientific theories are quite different things.
Gathering evidence does not prove a scientific theory to be true. The evidence instead shows that the theory is consistent with reality to within experimental error, and only in the case of the evidence at hand. Experimental evidence provides confirmation. It does not provide proof. On the other hand, one crummy piece of well-validated conflicting evidence makes a scientific theory fall apart. In the case of Newton's theory of gravitation, that one crummy piece of conflicting evidence is the precession of Mercury. Newton's laws predict a different value for the precession of Mercury than observed. Those observations falsify Newton's laws.
Lets not forget Einsteins relativity either :)
Lets put that way.
Suppose you kick MATHEMATICS to oblivion ,Can you have science
Then it wouldn't make much sense to have the discussion in a math forum. :-p
