How is the Answer to 3(d) Found in Simple Harmonic Motion Problem?
8 replies · 2K views · last reply
tahmidbro
Simple harmonic motion problem:
How is the answer to 3 (d) is found?
N/A
  • Graph fig D of displacement in cm against time in s for simple harmonic motion: a red sinusoid with amplitude 3 cm, crossing zero at 2, 6 and 10 s, with a point labelled Z at t = 6 s.
  • Printed answer key for question 3 parts (a) to (e): (a) repeating isochronous oscillations from a restoring force proportional to displacement; (b) 1.55 m; (c) 3 cm; (d) 6 m s^-1; (e) a sine curve shifted from fig F by a quarter cycle.
tahmidbro said:
Homework Statement:: Simple harmonic motion problem:
Relevant Equations:: N/A
Welcome to PF.
Are you familiar with how to find velocity from a position versus time function?
Yes. I have drawn a tangent with the curve at 'z' and calculated the gradient.
Gradient = ( 3+3 )/(7-5) = 3 cm/s = 0.03m/s.
But the answer is 6m/s. Will you please tell me how?
I have used a derivative to calculate the velocity at that point, and also get a much smaller number than the answer key. If the amplitude is 3cm and the period is 8 seconds, the peak velocity is much less than the 6m/s that is listed as the answer.
Do you know how to do this calculation with a derivative? Also, can you check that answer with the instructor or a teaching assistant?
Will you please share your calculation here? are you using v = -Aw sin(wt) ? ( this equation is not in the chapter of the exercise )
well, I am studying by myself. I do not have any instructor or a teaching assistant.
Yes, good. Differentiating that cos() function does give that derivative.
w = 2pi/8 =0.785
A = 3/100 metre . For maximum velocity at 'z', sinwt = 1
v= Aw = 0.785 x 3/100 = 0.0235 m/s
But the answer from the book is 6 m/s. How do I get that?
As I said, it looks like the answer provided is wrong. And not by a little bit!
Okay , Thanks for the help!
