How Is the Horizontal Distance Calculated When a Stone Drops on a Moving Log?
  • Thread starter Thread starter eureka360
    Horizontal
The discussion centers on calculating the horizontal distance a stone falls when dropped from a 75-meter-high bridge onto a moving log traveling at 50 meters per second. Participants initially question the provided answer of 20 meters, suggesting it seems incorrect given the log's speed. By applying the displacement equation for the stone's fall, they conclude that the correct horizontal distance should be approximately 200 meters. The consensus is that if the values are accurate, the calculated distance aligns with the log's velocity. The conversation highlights the importance of verifying calculations in physics problems.
eureka360
hi guys.. could you please explain why 2.0x10^1 meters is the answer of the horizontal distance between the log and the bridge when the stone is dropped from rest from a 75-m-high bridge and lands on the log as it passess under the bridge if the log moves with a constant speed of 50 meters per second?
Are you sure the answer is 20 meters? Its either ur answer is wrong or that the log is travellin at a speed too fast in water!
Doesn't sound right. From the equation of the displacement of the stone y = 75 - \frac{1}{2}gt^2 you can obtain the time it takes to fall down, by setting y equal to zero and solving for t. Further on, use that time to obtain the distance of the log at the moment just before the stone is dropped.
well. The answer should be approximately 200 if the values given are correct. Or else, there may be some error in the question.
Yes, it's near 200 [m].
the log is traveling 50 meters per second.. yeah i think its 200 meters..ok.. i got it.. thanks guys...
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
