How Is the Spring Constant Calculated from Block Compression and Friction?
1 reply · 4K views · last reply
soul5
A 1.8kg block slides on a rough, horizontal surface. The block hits a spring with a speed of 2.0m/s and compresses it a distance of 0.11m before coming to rest. The coefficient of friction between the block and the surface is 0.560. What is the force constant of the spring?
Ep=1/2kx^2
Ek=1/2mv^2
I used Ek=1/2mv^2 to find Ek and I got 3.6J. I can use Ff=uFn to find force friction, but I don't know what to do? help.
Since you know the mass of the object you would also know the Force of Gravity. Since force of gravity = Normal Force whenever its perfectly horizontal, then you could use that number you got times mew to get your frictional force
