How is torque actually measured when using a torque wrench?
  • Level: Undergrad
  • Thread starter korwynkim
    Torque Wrench
1 reply · 3K views · last reply
korwynkim
Diagram of a torque wrench drawn as a yellow shaft with a circular nut-socket head at top and a black handle at bottom, with force F pointing left at the handle and dimension d measured from the head to the handle.
Take this picture for example. Assume this picture represents a torque wrench applying torque on a nut, and a force F is applied at the centre of the black handle perpendicular to it. The force applied to the nut is:
Torque = Fd
There are times when a nut is in a very inconvenient location and you can't fit a torque wrench on it. Sometimes, a crow foot extension will be able to reach it. The problem is, changing the lever arm changes the torque.
Case 1: The common knowledge is that if the extension is at 90 degrees to the torque wrench, the torque applied to the nut doesn't change.
Torque = Fd (regardless of x)
Diagram of a torque wrench with a yellow handle and a grey hexagonal nut at the left end. Dimension x is marked horizontally from the nut to the pivot, a 90° angle sits at the pivot, dimension d is marked vertically from the pivot to the bottom, and force F points left at the black grip.
Case 2: I have also heard that in order for the torque to remain the same, the distance from the handle of the wrench to the nut should be kept the same as the distance from the handle to the pivot point.
Torque = Fy = Fd
Diagram of a torque wrench with a yellow handle and black grip, a grey hexagonal nut at the head, a force F pointing left at the bottom, dimension d along the handle, and a slanted line labelled y from the nut to the handle's end.
Case 3: Distance for torque should be measured from the handle to the nut perpendicular to the force applied.
Torque = Fx
Diagram of a torque wrench drawn in yellow with a grey hexagonal nut at the head, a black handle with an arrow labelled F pointing left at its centre, and a vertical distance marked x from the nut to a horizontal reference line.
What is the correct method to measure torque applied to the nut?
Case 1 is correct. Case 3 is also correct, but is obviously less mechanically advantageous, unless it gets you round an awkward obstacle.
Case 2 is not correct. For this to work, the force would have to be perpendicular to y.
