How is twin paradox resolved in case of no/zero acceleration?
131 replies · 23K views
DaleSpam said:
If A kills B while they are distant
this can only happen if something is sent from A to B and the max speed it can be sent is speed of light. when accounted for that and transition to B's frame of reference all paradoxes/confusion disappears?
however if we were to take a case where A can kill B instantaneously from a distant:
would it work? i mean would the whole thing won't integrate into the theory of relativity. won't we have "mismatches" that cannot be explained?
Yes.
If you make an unphysical assumption you will get unphysical conclusions.
A and B are perpetually inertial twins separated at age 0, correct? B is 25 when he dies in all frames. Therefore, since in A's frame A is 50 when B dies the time dilation factor is 2. 25/2 is 12.5 so A is 12.5 years old in B's frame when B dies.
tiny-tim said:
they don't disagree on their age, they disagree on their rate of ageing
(they don't disagree on their age because they can't make measurements at what they both agree is at the same time)
Well don't they disagree on both?
1. rate of aging
and
2. age
because for 2, so just need to bring them both into same frame of reference and compare.
they can make measurements by bringing them (stationary and moving twin) into the same frame of reference at a particular point in time.
both are correct and it depends upon who is brought into the frame of reference of who, or more generally, what frame of reference are they finally compared in?
i.e. whether the stationary Earth is accelerated to match the speed of the spaceship
or the spaceship is slowed down to (a stand-still) to match the speed of the spaceship
or some other common/same frame of reference
San K said:
Well don't they disagree on …
2. age
No!
… it depends upon who is brought into the frame of reference of who …
exactly! … so what are they disagreeing on? :confused:
tiny-tim said:
No!
when they are in same frame of reference there is no disagreement.
however when they are in different frames of reference (speed) then
isn't there disagreement on both
1. rate of aging
2. age
however it certainly gets resolved when the bought on same frame of reference
for example there are twins A and B.
A says B is older, B says A is older
now both are correct, however if only one of them (A or B) is brought to the other's frame of reference...then in hindsight, we can say...who was correct...
i.e. we can make either of A or B to be correct, in a sense, depends upon who moves ...assuming...only one of them is allowed to "move" (back into others frame of reference)
yes
… , however if only one of them (A or B) is brought to the other's frame of reference...then in hindsight, we can say...who was correct...
no!
they were both correct …
you just said so yourself!​
tiny-tim said:
yes
no!
they both are correct, when far...i.e. different frame of reference.
however when brought into same frame of reference...depending upon who was moved (taking a simple case) ...one of them will be older than other...
Yes, but they were still both correct …
where is the paradox? :confused:​
In classical physics as well as in SR, they are always in the same reference system; as a matter of fact, they are always in an infinite number of reference systems.
Is that clear to you so that it's just a matter of formulation, or are you perhaps not familiar with the definitions of classical mechanics?
[...] i.e. we can make either of A or B to be correct, in a sense, depends upon who moves ...assuming...only one of them is allowed to "move" (back into others frame of reference)
Whatever inertial reference system you choose, the prediction will be the same.
For example:
1. As determined with a system in which the "stay-at-home" is always in rest (approximately):
- Nearly all the time the traveler's clock appears to be slowed down due to speed.
2. As determined with a system in which the traveler is in rest during the first leg:
- Nearly all the time the stay-at-home's clock appears to be slowed down due to motion.
- during the second leg the traveler appears to move much faster than the stay-at-home, and his clock appears to be much more slowed down.
Calculation shows - as it ought to be - that the results of both descriptions are the same.
Harald
San K said:
Twin paradox where twins do not meet
Is resolved by the fact that:
Both are in different frames of reference and not comparable.
Both are correct if they say the other aged faster because they both are right in their frame of reference/point of view.
No!
Special relativity uses the same concept of a reference frame as does Newtonian mechanics. Reference frames extend to infinity. An object can be described from the perspective of any frame of reference, but the object isn't "in" anyone of those frames (to the exclusion of others).
As far as the resolution of the paradox, what paradox? There is only an apparent paradox that results from the erroneous thinking that because A sees himself as being older than B then B must necessarily see herself as being younger than A. There is no paradox here; there is only erroneous thinking.
