How long does a bat contact a baseball to reverse its direction?
  • Context: Undergrad
  • Thread starter Thread starter gnome222
    Baseball Physics
7 replies · 3K views
gnome222
<< Moderator Note -- thread moved to the HH forums >> [/color]
a pitcher throws a 1.5kg baseball with speed 25m/s. it hits the bat and return in opposite direction with same speed. the force that bat exerted on ball is 50N. For how long was the bat touching(in contact) the ball? I used: delat t * F = m*delta velocity delta t 50N = 1.5(25-(-25)) and i got t=1.5 s. Is it correct? It does not seem like.
That's a pretty happy baseball. Are you sure of that 1.5 kg?
Chet
Chet
yes
gnome222 said:
yes
A major league baseball has a mass of 5.25 oz (0.15 kg). That 1.5 kg is an obvious typo.
And, please, don't try to play baseball with a 1.5 kg baseball. If you got hit by a fastball, it would be "lights out."
Chet
o
Chet
ok, but under the conditions described what would be time?
gnome222 said:
o
If you are asking whether you solved the problem correctly, given the obviously faulty data, then the answer is yes.
Chet
force is the rate of change of momentum.
Thus, you have been given the change in momentum, the force excerted.
So,
t=Change in momentum/force
=2*1.5*25/50=75/50=1.5
Yup, your answer is correct
