How Long Does It Take for a Space Station to Rotate Once?
The discussion revolves around a physics problem concerning the rotation of a space station designed to simulate gravitational acceleration for astronauts. The specific focus is on determining the period of rotation for the outer ring and the radius required for an inner ring to simulate different gravitational accelerations.
  • Participants discuss the relationship between centripetal acceleration, angular velocity, and period of rotation. There are attempts to derive the period from angular velocity and to relate the radius of the inner ring to the required gravitational acceleration.
Some participants have provided guidance on using the formula for period in relation to angular velocity. Others are exploring how to derive the radius for the inner ring based on known values of acceleration and angular velocity. The discussion is active, with various interpretations and approaches being considered.
There is a lack of explicit information regarding the radius of the inner ring, and participants are working within the constraints of the problem's requirements for simulating gravitational accelerations on different planets.
physicsma1391
[SOLVED] Centripetal Acceleration, etc.
A space station is being built for astronauts to begin training for colonizing other planets. The rate of rotation is chosen so that the outer ring (r=2150m) simulates the acceleration of gravity on the surface of Venus (8.62m/s^2).
How long does it take the station to rotate once around its axis (i.e. what is the period?)
What should the radius be of the inner ring so that it smulates the acceleration on the surface of Mercury (3.63m/s^2)
I have no idea what to do but perhaps
Fc=ma
ma=m(Vt^2)/r
a=Vt^2/r
Vt=136.1m/s
136.1m/s=2150[tex]\omega[/tex]
[tex]\omega[/tex]=.0633rad/s
at=r[tex]\alpha[/tex]
8.62=2150[tex]\alpha[/tex]
[tex]\alpha[/tex]=.004rad/s^2
not sure where to go from here
you have the correct "omega", now use your formula for the period in terms of omega.
what formula is that?
Period = 2*pi / omega
that one is certainly in your textbook somewhere
hmm.
what are the units on the period? radians?
time...
seconds
ohh hahaha ok
for the second part of the question, I'm thinking it has to do with omega being the same for both radii?
but how can you find r using accel. and omega?
omega is the same for both radii.
so find v for the smaller radius using omega
then you know 'v'. also you know what 'a' must be.
write the formula that relates 'a' to 'v' and 'r' and solve for 'r'.
how do i find v for the smaller radius? isn't the equation Vt=r(omega)?
yes r*omega
but i don't know the radius of the smaller circle
i only have omega and the acceleration of gravity
I know. you are going to solve an equation for 'r'. Write down the equation you are going to solve. the equation for centripetal acceleration.
a=vt^2/r
now substitute in vt in terms of r and omega (post #10)
then you'll have an equation for a in terms of r and omega. a is known. omega is known. so solve that equation for r.
  • · Replies 28 ·
  • · Replies 20 ·
