How Long Does It Take for Red Blood Cell Count to Normalize After Blood Loss?
  • Context: Medical
  • Thread starter Thread starter lisab
    Blood Cell Time
The discussion centers on the time required for red blood cell (RBC) counts to normalize after a person experiences moderate blood loss, exploring factors influencing this recovery, including iron intake and physiological processes involved in erythropoiesis.
  • Some participants suggest that the recovery time for RBC count after moderate blood loss could be on the order of days or weeks, depending on the amount of blood lost.
  • There is mention of the role of iron intake in the recovery process, with some arguing that while RBCs can be produced, iron deficiency may lead to continued anemia due to impaired oxygen transport.
  • One participant states that it takes approximately 120 days for RBCs to mature, but acknowledges that factors can accelerate this process.
  • Another participant claims that erythrocyte production takes about 4 days and is primarily stimulated by hypoxia rather than iron intake.
  • There is a correction regarding the timeline of erythropoiesis, with one participant clarifying that while erythropoiesis takes around 7 days, mature RBCs circulate for 100-120 days before being recycled.
  • Some participants note that the total turnover of blood components is crucial in the context of anemia recovery, and that medications can potentially shorten this turnover time.
  • One participant highlights that blood loss also results in the loss of iron, which could lead to microcytic hypochromic anemia if dietary intake is insufficient.
Participants express differing views on the timelines and factors affecting RBC recovery, with no consensus reached on the exact duration or the primary limiting factors involved.
There are unresolved aspects regarding the physiological mechanisms of erythropoiesis and the role of iron, as well as the varying impacts of different amounts of blood loss on recovery time.
lisab
Staff Emeritus
If a person loses enough blood to become moderately anemic, how long does it take for the red blood cell count to return to normal? I mean roughly...would it be on the order of days, weeks, or...?
Is daily iron intake a typical limiting factor in this process?
Biology news on Phys.org
The second question third paragraph.
http://www.runnersweb.com/running/r...ning/news/rw_news_20040809_BloodDonation.html
Now this is only a 'rough estimate' for only 450mL of blood loss. Losing more or less blood will obviously effect the recovery time and also the rate of regeneration. Blood is on a positive feedback so lower oxygen being sent to the body will cause more blood cells to be created etc. (AFAIK)
I'm not exactly sure about the iron question but I'll take a stab at it.
Iron's function in the blood specifically has to do with the hemeoglobin. So the blood will still be created but you will still remain anemic because your blood can not properly transfer oxygen. It is important to keep your iron intake up to ensure that this doesn't occur.
120 days it takes to mature a RBCs but there are things that can push that envelope forward.
Production of erythrocytes takes about 4 days, and is stimulated by hypoxia, not iron intake:
http://faculty.ucc.edu/biology-potter/life_cycle_of_the_erythrocyte.htm
The physiological 'iron cycle' is not that well understood:
http://www.ncbi.nlm.nih.gov/pubmed/17014365
http://bmb.oxfordjournals.org/cgi/pdf_extract/37/1/25
http://scienceweek.com/2005/sb050218-4.htm
that statement is factually not correct but I do think they are talking not of erythropoesis , which is 100-120 days...they are referring to recruitment from the marrow of mature RBC's which is about 4 days. The cells develop in the bone marrow and circulate for about 100–120 days in the body before their components are recycled by macrophages.
The total turnover for anemia is what matter most. And it can be shortened with meds and other methods we surgeons use.
Err, well erythropoiesis takes around 7 days to complete. They are released from the bone marrow as reticulocytes and it takes around 2 of those days for it to mature into erythrocytes.
The life-cycle of the erythrocyte is generally accepted as 100-120 days. At which point the get sort of 'eaten' up mostly by the spleen.
This is only part of the problem though because you lose a lot more than just erythrocytes when you bleed out... they all will get regenerated but erythrocytes is only part of the problem.
EDIT: As well I noticed a mistake I made in my first post, I said positive feedback, it should be negative feedback. I explained it correctly just used the wrong feedback term :smile:. As well it is for the most part controlled by the kidney, which regulates the production of blood cells based on how much oxygen it is receiving. So if you lose blood it will receive less oxygen therefore increasing the amount of blood cells being produced.
Yes, when you lose blood you definitely lose your iron as well. In that case, iron deficiency in diet would limit recovery and you'd get a clinical picture of microcytic hypochromic anaemia. That's similar to occult losses of blood, such as from the Gastrointestinal tract that typically cause iron deficiency anaemia. On the other hand, with a case of haemochromatosis, you'd see a typical picture of normocytic normochromic anaemia.
Timeline for recovery is already stated in above posts.
  • Poll Poll
38K
