How long will it take for coffee to reach the perfect temperature
  • Thread starter Thread starter ashvuck101
    Coffee Temperature
The discussion focuses on calculating the time required to heat coffee in a microwave from an initial temperature (Tc) to a desired perfect temperature (Tp). The key equation used is Q = mC(ti - tf), where Q represents the heat energy in joules, m is the mass of the coffee, C is the specific heat capacity (4.186 J/g°C), and ti and tf are the initial and final temperatures, respectively. For a microwave delivering 750W, it was determined that reheating 140mL of coffee from 22ºC to 83ºC takes approximately 47.6 seconds, confirming that the calculations align with physical principles.
  • Understanding of thermal energy transfer and specific heat capacity
  • Familiarity with the concept of power in watts
  • Basic knowledge of unit conversions (Joules, seconds)
  • Ability to manipulate algebraic equations
  • Study the relationship between power, energy, and time using the formula P = E/t
  • Learn about specific heat capacities of various substances
  • Explore the principles of thermal equilibrium and heat transfer
  • Investigate practical applications of microwave heating in cooking
Students in physics or engineering, culinary professionals interested in food science, and anyone seeking to understand the thermodynamics of heating liquids.
ashvuck101
4. Your half- finished cup of coffee has cooled down to a temperature Tc. You like your coffee to be at the perfect temperature Tp. You put your cup, containing x mL of coffee, into the microwave. Assume 1mL of coffee has a mass of 1g.
a. How much energy will it take to restore your coffee to its “perfect” temperature? Assume that coffee has the same thermal properties as water and that the cup itself gains negligible heat from the microwave.
b. The microwave delivers energy to the coffee at a rate of P watts. How much time should you set the microwave to heat your coffee to the perfect temperature?
c. If the microwave delivers 750W to the coffee, how long will it take to reheat the 140mL of the coffee from 22ºC to 83 ºC?
Q=mC(ti-tf)
okay i get the first bit
Q=m.4.186.(Tc-Tp)
in part b that gets me?
how does that tell me how long it takes to heat up to
Q=m.4.186.(Tc-Tp)
if you get what i mean
Hi there,
You are getting there. Q is the amount of heat the you need to "input" to your coffee to heat it up to your perfect temperature. This amount of heat will be given in joules (J).
The power of your microwave only tells the rate of energy delivered to your coffee: 750W = \frac{750J}{1s} =
Does that help you a bit. Cheers
but how do i know that it is 750j per sec...and not 750kj per min or something like that it just says the rate is 750watts
Time is usually measured in seconds;
P = W/t or E/t,
where W and E are, respectively, the work done or energy transferred in time t (usually measured in seconds).
You can try this site if you want to know a little more about power:
http://en.wikipedia.org/wiki/Power_(physics )
Hope it helps.
A Watt is 1 J/s, by definition.
oh ok i should have look up watts up first i just thought it was a unit of energy
thanks
so did you get 0.0476 sec or did i do something wrong
That is too short. The actual time will be something reasonable ... reheating a cup of coffee in less than 1/20 sec in a microwave is not reasonable :smile:
Hint: check the units in your numbers, especially m and C.
does 47.6sec sound right?
Yes. :smile:
  • · Replies 41 ·
