How many numbers are there between 0 and 1
  • Context: High School
  • Thread starter Thread starter Brian Preece
    Numbers
The discussion centers on the nature of numbers between 0 and 1, exploring definitions, representations, and the implications of quantization versus continuity in mathematics and physics. Participants examine the decimal number line, the concept of infinite digits, and the relationship between mathematical ideals and physical reality.
  • Some participants assert that according to a specific definition, there are no numbers between 0 and 1, as each number occupies a defined range on the number line.
  • Others argue that with the addition of digits, the number of values between 0 and 1 increases, potentially leading to an infinite number of representations.
  • A participant suggests that the concept of infinite digits leads to ambiguity in defining a number's position on the number line.
  • Some participants propose that the number line should reflect quantization, as dimensions and quantities in engineering are often treated as discrete.
  • Others challenge the idea of quantization, stating that mathematical objects do not necessarily correspond to physical reality and that the continuum of real numbers is essential for calculus and other mathematical operations.
  • There is a contention regarding the indistinguishability of numbers with infinite digits, with some suggesting that this leads to an infinite number of indistinguishable values at a precise location on the number line.
  • Participants express differing views on the applicability of quantum mechanical principles to the concept of numbers and the number line.
Participants do not reach a consensus; multiple competing views remain regarding the nature of numbers between 0 and 1, the implications of quantization, and the relationship between mathematical representations and physical reality.
Some arguments depend on specific definitions of numbers and quantization, which may not be universally accepted. The discussion reflects a range of assumptions about the nature of mathematical objects and their correspondence to real-world phenomena.
Brian Preece
The definition of a number on the decimal number line from British Standard 1959 (if my memory serves me right) says that a number occupies a range of values, on the number line, between -50% and +49% of the least significant digit and so each number is separated from its neighbour by 1% of the least significant digit. This means that the number 0 occupies the range -0.5 to +0.49, and the number 1 between 0.5 and 1.49. In this case there are no numbers between 0 and 1.
However if you add another digit (0.0 to 1.0) the answer returns nine. As you add digits the number increases. Some would say that, if you have an infinite number of digits in each number, then you can have an infinite number of numbers on the number line between 0.000... and 1.000... (beware the ellipsis). I refute this condition because, if the number has an infinite number of digits, then the last digit cannot be determined. Hence the number cannot be defined as above and cannot be positioned on the number line.
Another consequence of this definition is that the Quantum Mechanical theories of Heisenberg's uncertainty and Pauli's exclusion principles can be assigned to the number line.
This sounds as a definition for accountants, not mathematicians and other scientists.
Correct. The representation of a number in the decimal system has its limits and is just that: a representation. E.g. ##\pi## cannot be represented exactly in this way. The amount of infinite numbers in this representation exceeds the amount of finite numbers by far!
No. You cannot misunderstand the number line and use this flawed concept to press HUP into it. One has nothing in common with the other regardless how you put it.
Answer1. There are as many real numbers as there are real numbers between 0 and 1.
Answer2. The cardinality of the interval ##(0,1)## is the cardinality of the continuum.
There are no integers satisfying ##0<k<1##.
Quantum mechanical propositions are inapplicable to numbers.
My background is in engineering. In this discipline the numberline is quantised as it refers to quantities (integer), or dimensions, which are quantised by tolerances similar to the above definition (even if we commonly use an approximation of pi). It is also currently the accepted theory that all dimensions are fundamentally quantised (well below the level of any engineering measurement).
As mathematics is the main method of describing nature, then I suggest that the numberline should reflect this and cease to be a continuum.
Furthermore I suggest that if a number has a precise location on the numberline, with an infinite number of digits in any decimal (including hexadecimal, etc) system, then it will be indistinguishable from the next number in the sequence. In other words an infinite number of numbers can occupy a precise position on the numberline. Please forgive my continued use of metaphor, but I contend that numbers are fermions, not bosons.
  • Haha
There is a fundamental difference between mathematical objects and real world objects. E.g. there is no such thing as a circle in the real world. Latest under the electron microscope and circle will look like anything but not a circle anymore. Nevertheless, we can happily work with ##x^2+y^2=z^2## and its deduced formulas for sine, Pythagoras etc. Mathematical objects are an idealization. They do not demand a real world correspondence. There isn't even a straight line in the real world, but we all live well with the fact that our I-beams are.
Your concept of indistinguishable is based on real world limitations. They do not apply to mathematics. From which digit on do you call two numbers indistinguishable? The closest way to such a constructive concept is to define, that two numbers are indistinguishable if a computer program doesn't come to a halt if it tries to figure out a difference. But this allows arbitrary long runs, not limited by human properties. But this leads back to the question of a suitable description of numbers. The constructive approach to mathematics is a stony path, and in my opinion isn't superior to the abstract concept of Plato's heavenly ideals.
What is a location of a number on the number line? Do you describe it in terms of..numbers? You would be cheating!
Do you sometimes use calculus? Do you ever need to do integrals, or take derivatives? If you answered YES, you are automatically using the "continuum" of real numbers, not any form of quantization.
Brian Preece said:
My background is in engineering ... I suggest that the numberline should reflect this and cease to be a continuum.
These two statements are in direct contradiction to each other.
  • Haha
No it isn't.
Again, not true. Even by your original definition you'd get more numbers just by having closer tolerances. Quantities don't even have to be integers. This is a self-defeating argument.
This is also incorrect, as has been said already. I suggest that instead of trying to make your own rules, you learn why we define numbers the way we do.
A measurement, to some degree of precision, can be considered to occupy a range on the number line, but every real number (which includes integers) occupies a specific location.
This is flawed reasoning. For any given real number, there is no "next" number in either direction. It's possible to have multiple representations of some real numbers; e.g., the decimal representations 0.5 and 0.499... (the ellipsis has a defined meaning) are both representations of a single number: the fraction ##\frac 1 2##.
The problem I have goes back to Newton and calculus. The derivation of dx/dy uses to the statement that delta x and delta y (within the limit) go to zero. They never actually equal zero. It is for this reason that I contend that the number line is not a continuum. In the decimal system 1/3 is an irrational number (1.333 repeating) however in a system to the number fifteen, 1/3 can be written as 0.5. The choice of decimal systems has a bearing on the definition of numbers.
Everyone believes that pi is an irrational number, it cannot be defined precisely as a decimal, but is there proof that it cannot be defined as a finite number in any decimal system?
As others have said, you are confusing the representation of a number with its definition and properties. Mathematics is in no way dependent on the decimal notation. The properties of ##\pi##, for example, are independent of how you choose to represent it.
In particular, an "irrational" number is a number that cannot be expressed as the quotient of two integers. ##\pi## is irrational. See , for example:
https://en.wikipedia.org/wiki/Proof_that_π_is_irrational
Any number that is the ratio of two integers is by definition a rational number, excluding of course ratios where the divisor is zero. It's not a coincidence that the root of "rational" is "ratio."
##\pi## is very much a finite number, existing as it does between 3 and 4 on the number line.
Since the OP's question has been asked and answered, I am closing this thread.
  • · Replies 55 ·
11K
  • · Replies 16 ·
  • · Replies 93 ·
22K
  • · Replies 24 ·
  • · Replies 16 ·
