How many photons are reflecting?
  • Context: Undergrad
  • Thread starter Thread starter Alvydas
    Photons
The discussion revolves around the question of how many photons from a diode laser are reflecting off a mirror. Participants explore the relationship between the laser's power, the energy of individual photons, and the reflectivity of the mirror, while also delving into the nature of photons and their properties.
  • Some participants note that the number of photons reflecting depends on the mirror's reflectivity and the intensity of the laser.
  • One participant calculates that a 10 mW laser emits approximately 3.3E16 photons per second, but emphasizes the need for the mirror's reflectivity to determine how many are reflected.
  • Another participant questions how many photons are "touching" the mirror at any given moment, suggesting that this is a statistical question and may not have a definitive answer.
  • Some participants argue that photons do not have a measurable length, while others discuss the implications of defining a photon's length in terms of its wavelength.
  • There is a debate about whether it is more accurate to say that photons do not have a length or to assert that their length is zero.
  • One participant expresses frustration with the original question, suggesting it lacks meaning and clarity.
  • The discussion touches on the nature of electron emission and whether an electron must move at the speed of light to emit a photon, with some participants clarifying misconceptions around this topic.
Participants do not reach a consensus on the original question regarding the number of photons reflecting off the mirror. There are multiple competing views on the nature of photons, their properties, and the implications of their behavior in this context.
Participants express uncertainty about how to quantify the number of photons "touching" the mirror at a specific moment, highlighting the statistical nature of photon behavior and the complexities involved in defining photon properties.
Science news on Phys.org
Depends on the mirror, and the intensity of the laser.
The energy of a 650 nm photon is E = hc/λ = 3E-19 J. So a 10 mW output would correspond to 3.3E16 photons/s from the laser. Then you would need to know what the reflectivity of the mirror is to determine how many are absorbed vs. reflected.
You have calculated how many photons was emitted per second.
But I am asking how many of them are touching mirror at current moment.
I think we need length of photon also.
Lest say reflectivity is 100%.
We don't know. We can't know. It is statistical in nature. And this ignores the difficulties of saying a photon "touches" the mirror in the first place. At the quantum level things are not like they are at our scale.
I don't think that photons have a length. I cannot even think of a way that the length of a photon could be measured in principle.
As far as the expectation for how many are touching "now", the answer would be zero. This should be obvious from the well known properties of statistical distributions. If you want to know the expectation for how many are touching over some finite time period of duration Δt then simply take 10 mW times Δt to get the energy and divide that by the energy per photon above.
Well, I think many people think of it as the wavelength of the EM wave. However this really depends on what you view photons as. Personally I only use photons to describe the quantized interaction of the wave, in which case the wavelength of a photon doesn't make any sense. However that is just my own way of thinking of it, mostly as a result of multiple discussions here on PF about what a photon is.
Yes, I agree. Roughly speaking I think of a photon as a quantized excitation of the EM wavefunction. I guess you could define the photon's length by taking its wavefunction and doing some sort of 95% confidence interval, but that seems awfully artificial.
Yes: if they had "a length" and, of course, all photons of the same energy would have to be identical, then they would all have to have the same "length", whatever mechanism happened to produce them. The only possible value of length that would satisfy this requirement is Zero. This agrees with the accepted 'extent' of a photon.
Consider this, also. The wavelength of visible light is conveniently small to allow you to consider the photons as having a nice short length (in an arm-waving kind of a way and something related to the wavelength) but how long would the photons of an lf radio wave need to be - with a wavelength of a couple of km? Best not try to allocate a length, I think.
I never like asserting that the length or size of a particle is zero since that always unfortunately conjures up the idea of classical point particles zipping around, and even non-classically the wavefunction is not a dirac delta in general. So I would rather say that it doesn't have a length than to say that it has a length and that length is zero.
What is your opinion of saying that it doesn't have a length rather than saying that its length is 0?
You people should not argue with each other on this matter and let the OP get away with asking a rather meaningless question. I mean, "... Touching mirror at current moment..."? No one questioned that?
Zz.
But to emit instantaneously electron could move much quicker then c ?
Huh? No, an electron has mass, so it cannot move quicker than c. That said, I have no idea how you think that fits in with the rest of everything.
Btw, coherent states, like lasers, don't have a definite number of photons.
So very short time after emission we have the same atom like before,
because any parts of it can not change their dislocation due c limit so quickly
+ just emitted new photon?
What does "dislocation due c limit" mean or have to do with emitting a photon. Are you under some confusion that a massive particle must move at c in order to emit a photon? If so, that is not correct, I don't know why you would think that.
Jan27-12 08:23 AM
Alvydas, Have you read the Rules of this forum, as I suggested to you recently? If you had, or if you do, and you have any understanding of the English language, then you will NOT post this speculation here. Remember what happened 10 days ago to this same ficticious whacko off-the-wall stuff. Your thread was locked until you reference some peer-reviesed journal/source. You have only rewittten the same old broken-down false ideas from you last attempt at posting here. Not to mention your ridiculous comparisons of theoretical subatomiic particles such as "fruits" and "apples"! You are either really stupid, or unbalanced, or drunk, or so emotionally attached to these uproven phony wastebasket garbage theories that you cannot control your own actions. Bye bye.
I do not think that electron must have some proper velocity to emit in classical way.
But instantaneous emission makes some confusion.
Like I mentioned after short time after emission we have the same atom + a new photon.
I am right?
If so (this atom is still is the same) why it can not emit 10 the same photons more?
Bobbywhy said:
Jan27-12 08:23 AM
I nothing had prosed at this tread. Do you ban even questions?
Either would be fine with me. No value or a value of zero would both avoid a specific length. Excluding the possibility of a value could be hard for some people to accept, though. But the whole idea of a wave function 'collapsing' when a photon is detected implies instantaneous transfer of information etc. etc. which is also hard to accept. It's all a bit too much for a normal brain, I think. :smile:
I am right?
Hold on. If the emission of a photon is by an electron dropping energy levels in an atom or molecule, the electron does NOT move anywhere. to my knowledge the change in energy levels can be instant because there is no motion here. It can't emit 10 photons because the change in energy levels gives up energy in the form of the photon and the electron is now in a new state. It can't go back and drop energy levels again, we would have to excite it first, which requires energy.
I am right?
In order to emit a photon (whether stimulated or spontaneous) the atom has to be in an excited state. After the emission it is in a non excited state. The energy difference between the two states is equal to the energy in the emitted photon. It cannot emit more photons unless it is re excited.
It can move to its ground state in more than one step, though, emitting two or more photons of the appropriate energy as it passes through intermediate states.
True, bu they wouldn't all be the same energy, as the poster was asking. At least, I think that's what he was asking.
Bobbywhy said:
Jan27-12 08:23 AM
Bit harsh, he has probably not received any tuition in this field but has interest.
I suggest learnin the real quantitative physics, grab a book.
Yes, that is why I said "non excited" rather than "ground." Although, I guess "less excited" would have been even more accurate.
Why? You may spread light onto very big photosensitive equipment and count them individually. Or decrease number of photons by semitransparent mirrors and count them individually also.
Yes, you understood what I am talking about.
Do atom's size really stays the same after emission?
If you think photon is a point than maybe question can be transformed to:
what size is space where we may find it at current moment?
There is one more interesting sequence from idea about point like photon.
First experiments for photoelectric effect maybe was not right understood.
They have varied intensity of red light and no photoelectric effect was obtained,
but even weak blue light made this effect.
But if photon is a point it can not overlap each other and therefore always acts alone on an atom. Even if experimenters arise intensity of red photons the atom can not catch two of them simultaneously because of their small/zero size.
But maybe here is possible some big enough intensity to produce photoelectric effect with weak photons? This maybe may suggest that they start overlap each other?
True, but if you take a slice of time, let's say 1 second, and count all the photons that impact the detector it will NOT match the next 1 second slice, or the next slice, or the one after. Each will vary in counts. If we have on average 100 counts per second, there is a 64% chance that each 1 second slice will have 90-110 counts, a 86% chance it will have 80-120 counts, etc. I didn't do the math so the numbers may not be exactly right, but that's the general idea, that the photons are generated randomly.
I hesitate to comment on their size, as it's not really that simple. At the quantum level we'd need to determine where we wanted to say the atom is since all its component particles exist as wavefunctions which don't have a defined position. As for the position of the photon, that is found by the probability amplitude of its wavefunction which depends on its energy and what it is interacting with. But the specific location is still random.
No, what would happen is that the atom would absorb multiple photons at once and transfer their energy to an electron to cause it to jump out of the material. This has nothing to do with photons overlapping, but with the sheer number of photons simply making it likely that an atom will absorb many at one time. (I'm not actually sure exactly what would happen, but I think an atom can absorb multiple photons at once)
@Alvydas ... It would be helpful if you would address the problems that have come up with your previous statements before throwing in some more - it makes you look somewhat "trollish".
eg. What did you mean by "length of a photon"?
(BTW: @ sophiecentaur etc, is is common for people to define "the wavelength of a particle" through the deBroglie relation as you well know. Isn't it somewhat pointless, however, to argue the toss before OP has explained what was meant?)
eg. what do you mean by "touching the mirror"? You know - considering that, on the scales that talking about "photons" makes sense, there is no such thing as a "surface" for the mirror.
For me, I don't understand the difficulty with the your question: what is it about reflection re photons that you don't understand?
Usually I'd take issue with the vagueness of your wording too - but I'm guessing that English is not your first language. Is that the case?
For instance:
... you seem to be saying that you think the atom is unchanged by interactions with photons. However, this is not correct. When an electron absorbs a photon, for example, it is not re-emmitted right away.
When you are considering the physics of reflection, you have a choice of models depending on what you are using to look at it. For the photo-electron level, you will do well with QED - which is pretty much the go-to model at this level.
... that's lecture 1, see all 8. He deals with reflection from a "surface" as one of the examples.
  • · Replies 26 ·
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 19 ·
