How much AC is there in a car battery
The discussion centers on the usable electricity in an 800 CCA 12-volt car battery, estimating it at approximately 0.5 kilowatt-hours after conversion. A standard car battery typically has a capacity of about 45 amp-hours, leading to this calculation. Users are advised to avoid deep discharging car batteries and to utilize a float charger to extend battery life significantly. Alternatives such as deep cycle batteries are recommended for applications requiring frequent discharges.
  • Understanding of car battery specifications, specifically 12V and 800 CCA ratings.
  • Knowledge of electrical conversion principles, particularly DC to AC conversion.
  • Familiarity with battery maintenance practices, including float charging.
  • Awareness of different battery types, such as lead-acid and deep cycle batteries.
  • Research the specifications and applications of 12V DC to AC converters, particularly 300W models.
  • Learn about the differences between lead-acid and deep cycle batteries for various applications.
  • Investigate battery maintenance techniques, focusing on float charging and its benefits.
  • Explore the impact of deep discharging on battery lifespan and performance.
This discussion is beneficial for automotive enthusiasts, hobbyists using electric-powered devices, and anyone involved in battery maintenance and optimization.
John1397
I am thinking there is about 1/2 kilowatt hour of usable electricity in an 800 cca 12 volt car battery after conversion is this right?
If you look at the specs for these devices they are about 300w
https://www.amazon.com/s/?ie=UTF8&keywords=12v+dc+to+ac+converter&tag=pfamazon01-20
Product description
Size:300WConverts DC 12V to AC 110V
• Dual AC Outlets
• Dual USB Ports
• This product is for DC 12V only, do not apply to DC 24V.
Specification:
• Output voltage: 110V ~ 120V AC
• Input voltage: DC 12V (10 ~ 15V)
• Rated Power: 300W
• Max. Power: 350W
• Peak Power: 600W
• USB Output: 5V/2.1A
• Ambient operating temperature range: 14°F - 140°F(-10°C - 40°C)
Safety Instruction
1. This product is for DC 12V only, do not apply to DC 24V.
2. DO NOT use with any appliance with dangerous voltage warning.
3. Plug the cord into your car AFTER the car starts
4. Do not leave the power inverter in the ON position while your car is off.
Attentions After Use:
1. Turn Off the power of the appliances
2. Pull out the AC/USB plug from the AC/USB sockets
3. Pull out the cigarette lighter after use
According to google, a standard car battery has a capacity of about 45 amp-hours. Not including inefficiency of conversion, that's 45*12/1000=0.5 kWh.
So yeah...
When I started flying electric powered model aircraft I used ordinary car batteries to charge the flight pack. I managed to kill a few car batteries by partly discharging them and forgetting to recharge them for a few days. Used like that they only lasted about a season/year. Even deep discharge batteries weren't much better. Eventually I got a car battery charger with a float setting and got quite religious about putting the car battery back on charge as soon as I got home and leaving on the float until it was needed. Used like that they lasted about three times longer.
In short my advice would be to avoid deep discharging the battery and try and keep it on a float charger when not in use.
Alternatively use a different type of battery that is more resistant to abuse and doesn't mind being discharged. Lead acid is excellent in many ways but the deep discharge problem can be a real problem. Once they're dead they're really dead.
12K
  • · Replies 23 ·
17K
11K
