How much charge will flow from the battery?
4 replies · 16K views · last reply
gillyr2
A 3500 pF air-gap capacitor is connected to a 32 V battery. If a piece of mica fills the space between the plates, how much charge will flow from the battery?
C= K*C_0
V= V_0/ K
Q= C*V
K of mica is 7
solved for the _0's and plugged into Q=CV
i used (C/K) * (V*K) = (3500 *10^-12F)/7 * 32V*7 = 1.12*10^-7C
its wrong but i don't know what else to do. help.
well you've canceled out the mica with your equation.
You know that capacitance depends linearly on the k value of the dielectric (assuming area and distance between parallel plates remains constant).
So effectively the capacitance of with the mica inserted is 7 * 3500E-12.
Q = CV.
Do they want the answer in C or e?
ok so it would be
Q = (7*3500*10^-12) * 32V
they want it in C. that gives 7.84*10^-7C which was my first answer but it is wrong.
The question is "how much charge flows from the battery?" (when you insert the mica).
Your (above) calculation gives the charge after inserting the mica. This includes the charge that was there already.
You just have to replace 7 by 6.
delta Q = kCo*V-Co*V = (k-1)Co*V
Is this the right answer?
