How much does the photon weighs?
  • Context: High School
  • Thread starter Thread starter tumor
    Photon
A photon has no rest mass, making the concept of weight inapplicable in traditional terms. However, photons possess energy and momentum, which allows them to exert gravitational effects, as described in general relativity. The discussion highlights that a box filled with photons weighs slightly more than an empty box due to the energy of the photons. Key references include the Pound-Rebka experiment and Lev Okun's paper on the concept of mass, which explore the gravitational interactions of photons.
  • Understanding of general relativity and gravitational interactions
  • Familiarity with the concepts of energy and momentum in physics
  • Knowledge of Einstein's momentum formula and its implications
  • Basic grasp of quantum mechanics, particularly the De Broglie principle
  • Study the Pound-Rebka experiment on gravitational redshift
  • Research Lev Okun's paper "The Concept of Mass" for insights on photon mass
  • Learn about radiation pressure and its implications in physics
  • Explore the relationship between energy and momentum in quantum mechanics, particularly E=pc
Physicists, students of physics, and anyone interested in the properties of light and its interactions with gravity.
tumor
Science news on Phys.org
russ_watters said:
A photon has no mass. "weight" doesn't apply.
Can you explain litlle bit more please?
Photons do not have mass, but they do have energy. Energy couples gravitationally in the general theory of relativity, and thus light does have weight. A box full of light actually weighs (very slightly) more than an identical empty box.
- Warren
tumor,
Or you may be thinking of radiation pressure. This is caused by an impulse that a photon imparts to an object upon reflection or absorption.
Is the frequency of a unique photon "traveling" in vacuum far from any gravitational source a constant? Thanks for any explanation
- Warren
Oops - I knew that.
Weight is a layman's term, not a scientific term. You need to be more precise as to what you are trying to measure. Its mass? The magnitude of the graviational force acting on it? The magnitude of any normal force acting on it?
Hi men,
Talking about this, when I saw for the first time the Einstein momentum formula for relativistic dynamic:
p=mv/[1-(v/c)^2]^(1/2)
I wondered what happens with photons:
v=c and m=0, so It is not determined.
But it has to agree with the De Broglie Principle: p=h/L
where p=photon momentum,
h=Planck constant
L=wave length of the photon's associated wave.
What happens?. How can I calculate the limit when v-->c and m--->0?
Consider m^2c^4 = E^2 - (pc)^2 where m is the rest mass. A photon has no rest mass, so E=pc. This allows you to talk about the energy and momentum of photon.
That's an interesting question. Does anybody know the answer?
I would guess that to make it meaningful you have to specify the order of the limits, ie something like
m/(1-v/c) -> something.
Can someone make sense of this? Or at least tell me whether this is just nonsense :wink:
Matt
To be honest, my physics tutor did it some time ago, but I can't remember how. Somebody asked him this in class, and he answered something by means of L'Hopital rule.
But I have been trying to employ L'Hopital rule for this limit without success.
What you are saying is agree with De Broglie principle:
E=pc=h/L
and quantum Planck principle too.
But for relativistic momentum ¡t is not obvious.
Sure it is. Asume you know the speed (energy) of the photon you now know the momentum.
How can I do that? Do I have to introduce c=E/p in the relativistic momentum formulae?.
The problem here is how to match Einstein relativistic momentum with De Broglie's principle, and I cannot see how.
What I posted was a lorentz invariant (m^2c^4 is invariant under lorentz transformations). So, assuming you know the wavelength you know the energy. You know the energy, you know the momentum.
if energy is the same thing as mass, couldn't you convert lights energy to mass? what would it be?
Yes, as I said, you can certainly use radiation to produce pairs of particles -- one matter and one anti-matter. If you smash gamma rays into a block of lead, for example, you'll get a shower of matter particles out of it.
- Warren
I don't believe the weight of a photon is a well defined quantity in that different people mean different things by the term weight of a photon. Normally the term "weight" refers to the force required to support an object in a gravitational field. I suppose you could say that the gravitational force on a photon is the "weight". But I personally stay away from that kind of definition myself.
By "a photon has no mass" it is meant that the proper mass of a photon is zero. However a photon has inertial mass (aka "relativistic mass" which is has due to the fact that a photon has momentum), active gravitational mass (due to the fact that light generates a gravitational field) and passive gravitational mass (due to the fact that light is deflected in a gravitational field). Keep in mind the famous experiment by Pound and Rebka on gravitational redshift. The paper they wrote on this topic was entitled "On the Weight of Photons". Also recall Lev Okun's paper "The Concept of Mass" that appeared in Physics Today in June 1989. In that paper Okun calculates the gravitational force on two photons moving in a Schwarzschild field, both in the radial direction and the horizontal direction. Okun concludes ..., a horizontally moving photon ... is twice as heavy."
For a calcultion which demonstrates that a box of photons weighs more than the same box with no photons in it see the paper "On the concept of mass in relativity" which is listed at http://www.geocities.com/physics_world/
The weight of an object is a well defined quantity in physics as well as in general relativity. I like the following definition. Its what people use the most and its quite reasoable. From The equivalence principle and the question of weight, Kenneth Nordtvedt, Am. J. Phys. 43(3), March 1975
The weight of a body is meant to be the force (e.g., the compression of a spring scale) required to either support the body in a gravitational field (gravitational weight) or to accelerate the body relative to inertial space (inertial weight).
The most rigorous definition of momentum is found by the implicit rule for defining (relativistic) mass. I.e. mass, m, is defined such that the quantity mv is conserved. The quantity mv is then defined to be the momentum. The relation p=mv/[1-(v/c)^2]^(1/2) is derived by assuming the particle can travel at speeds less than c (i.e. its derived only for tardyons). If you want to express the momentum in terms of energy then its E = pc, which is derived using Maxwell's equations. It then follows that m = p/c. If you want to express it in terms of mass then defined m = E/c2.
Pete
Why? Photons have no mass. They also have no "size" in any real sense. So most of the relativity stuff just doesn't apply, like the lorentzian contractions for instance.
Pete
Hi Pete. It's all right, but my question is: Does this formula for relativistic momentum have to converge to p=h/L when m--->0 and v--->c?. I mean, although this formula has not been built to deal with this conditions it should satisfy this limit.
  • · Replies 25 ·
10K
