How much energy to heat water (in Watts/Wh)
  • Context: High School
  • Thread starter Thread starter drzeus
    Energy Heat Water
This discussion focuses on calculating the energy required to heat one liter of water from 25°C to 60°C, which involves converting kilocalories to watt-hours. The correct calculation shows that 35 kilocalories equals approximately 40.67 watt-hours. The formula used is Energy (in joules) = specific heat capacity of water (4186 J/kg°C) * mass of water (1 kg) * change in temperature (35°C). The time factor is irrelevant when calculating total energy in watt-hours, as watt-hours measure energy, not power.
  • Understanding of specific heat capacity of water
  • Knowledge of energy conversion between kilocalories and joules
  • Familiarity with the relationship between watts and joules
  • Basic principles of thermodynamics
  • Learn about energy conversion formulas, specifically between kilocalories and joules
  • Research the specific heat capacity of various substances
  • Explore the concept of power versus energy in physics
  • Investigate practical applications of heating calculations in real-world scenarios
Students in physics, engineers working with thermal systems, and anyone interested in energy calculations for heating processes.
drzeus
I'm heating a liter of water from 25C to 60C. I'm under the impression that a Calorie (kcal) heats one liter of water by one degree, and so heating one liter by 35 degrees requires 35 Calories.
I want to convert this to Watthours but I'm not sure how...does bringing time into the equation determine how much energy I need to expend? For instance, is there a difference if I need to increase the temperature to 60C in 5 seconds versus a minute?
I could spend a few hours figuring this out for myself but I figured someone else could illuminate me with much less effort
The watt is a unit of power=change in energy/change in time. So the watthour is actually a unit of energy.
Watt is Joules/second. So a watthour is essentially joules/3600 (there are 3600 seconds in an hour).
To answer your question, yes the time required would matter if you were concerned about power. But since the problem asks for watthours, a unit of energy not power, the time required is of no relevance.
Can I convert kcals to watts in this instance? ...as in 4.184 calories/second, so .004184 watts would heat one cc of water by one degree? ...and in an ideal world (not accounting for conduction/convection/niggling details) a watthour would heat .004184 x 3600 cc's of water by one degree?
Damn, I screwed up my math and my units...I'm probably going to have to consider this deeper until my internal inconsistencies diminish enough to ask questions that actually make sense. Thanks for answering!
I think what you would do is convert kcal to joules and then joules to watthours.
I think I figured it out...your answer prompted me to look up energy vs. power and I realized I originally did the math [somewhat] correctly but forgot to account for time factors cancelling themselves out which led to an answer that didn't make sense and subsequent searches consisting of the wrong terms.
1 kcal = 1.162 watt hours so 35 kcal = 40.667 watt hours
Yup that's correct.
If you want the answer in watt hours you don't really need calories at all...
Energy (in joules) = specific heat capacity of water(joule/kg °C) * mass of water(kg) * change in temperature(°C)
= 4186 * 1 * (60-25)
= 146510 Joules
1 joule = 1 watt for 1 second
so to convert to watt hours divide by 3600
146510/3600 = 40.7 Watt hours.
= 146510 Joules
Thanks, I was going with what I knew offhand and was almost too tired to put two and two together
  • · Replies 23 ·
  • · Replies 66 ·
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 22 ·
