How much force needed to partialy lift object?
  • Context: Undergrad
  • Thread starter Thread starter JamesGreen
    Force Lift
The discussion focuses on calculating the force required to partially lift an object with uniformly distributed weight, specifically using a metal rod as an example. The formula derived indicates that the force needed to lift one end of the rod while the other remains on the ground is half the total weight of the object. This is established through the moments of force equation: mg x L/2 = F x L, where 'm' is mass, 'g' is standard gravity, and 'L' is the length of the rod.
  • Understanding of basic physics concepts, particularly moments of force
  • Familiarity with the formula for weight (W = mg)
  • Knowledge of uniform distribution of weight in objects
  • Basic algebra for manipulating equations
  • Study the principles of moments and torque in physics
  • Learn about the applications of force calculations in engineering
  • Explore examples of uniformly distributed loads in structural analysis
  • Investigate the effects of varying lengths and weights on force calculations
Students in physics, engineers involved in structural design, and anyone interested in understanding the mechanics of lifting objects with distributed weight.
JamesGreen
Hi,
Imagine you have an object where the weight is equally divided. What would be the formula to calculate the force needed to lift the object up to a distance without lifting it up completely. For example, a push-up, your feet keep touching the ground but you push your self up. How would one calculate that? If the mass, length, height and standard gravity are known?
Thanks in advance
Welcome to the Forum.
If the weight is uniformly distributed along the length of the mass, like a metal rod, for example; then the force you would need to apply to the one end, the other staying on the ground, would be exactly half the weight.
Proof using moments of force about the support point on the ground gives mg x L/2 = F x L where L is the length of the rod.
Diagram can be provided if you want one!
Thank you!
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 128 ·
11K
  • · Replies 22 ·
10K
