How Much Gas Leaked from the Tank?
The discussion centers on calculating the amount of gas that leaked from a tank with a fixed volume of 0.0800 m3, initially filled with an ideal gas at 4.00 atmospheres and 48.0° C. After a leak, the pressure dropped to 3.20 atmospheres at 20.0° C. The initial number of moles was calculated using the ideal gas law, yielding 12.1463 mol. The final number of moles can be determined using the final pressure, volume, and temperature, confirming that the volume remains constant at 0.0800 m3.
  • Understanding of the Ideal Gas Law (PV=nRT)
  • Knowledge of gas properties and behavior
  • Familiarity with unit conversions (e.g., pressure in atmospheres to Pascals)
  • Basic algebra for solving equations
  • Learn how to apply the Ideal Gas Law in various scenarios
  • Study the concept of gas leaks and their implications on pressure and volume
  • Explore the relationship between temperature, pressure, and volume in gas laws
  • Investigate real-world applications of gas laws in engineering and environmental science
This discussion is beneficial for chemistry students, physics enthusiasts, and professionals in engineering fields who are interested in thermodynamics and gas behavior in closed systems.
format1998
A tank with a fixed volume of 0.0800 m3 is filled with an ideal gas at a pressure of 4.00 atmospheres and a temperature of 48.0° C. Due to a small leak, some of the gas leaks out. Later it is found that the pressure in the tank is 3.20 atmospheres when the temperature is 20.0° C. How much of the gas leaked from the tank?
PV=nRT -> n=PV/RT
I solved for the initial number of moles using the initial values
n= [(405.2E3 Pa)(0.08m3)]/[(8.314 J/mol*K)(321K)]=12.1463 mol
I thought I could get the final volume by using
(P1*V1)/T1 = (P2*V2)/T2
and after I obtain V2, I thought I could get the number of moles so that i could plug it into n=PV/RT to get the final number of moles left
and then use the initial numbers of moles and subtract the numbers of moles left in order to give me the # of moles that escaped.
But ofcourse, the answer I came up with was ridiculous. I had a higher V2 than V1, which ofcourse doesn't make sense when some of the gas supposedly leaked out into the environment. Please help! Any & all help is much appreciated! Thank you in advance for your time...
You are just interested in knowing the number of moles of gas still in the tank - so that is the final volume. Since you know the final P, V and T, just determine the final n from that.
You can only use PV/T = constant (=nR) if n is constant. But n is obviously not constant in this case.
AM
Even though some of the gas leaked out into the environment, the final Volume of the gas remains as 0.08 m3? Is this what you mean by knowing the final Volume?
Yes. The pressure and temperature given (3.2 atm and 20C) is of the gas that is left in the tank after the leak occurs.
AM
You certainly have learned that the gas always fills the whole space available in the container. Gases do not have own volume: The volume is that of the container.
ehild
Thank you to both of you :)
10K
