How Much Heat Is Needed for Each Process in a PV Diagram?
  • Thread starter Thread starter Nellen2222
    Diagram Heat
The discussion revolves around a monoatomic gas undergoing processes represented in a PV diagram, specifically focusing on calculating the heat required for transitions between states 1 to 2 and 2 to 3. Participants are exploring the relationships between work, heat, and temperature changes in the context of thermodynamics.
  • Participants discuss the calculation of work done during the transition from state 1 to state 2 and express confusion regarding the heat required for the processes. There are attempts to apply the first law of thermodynamics and the ideal gas law, but uncertainties about the number of moles and temperature changes persist.
Several participants are actively engaging with the problem, raising questions about the application of specific heat capacities and the ideal gas law. While some guidance has been offered regarding the relationships between variables, there is still a lack of consensus on how to proceed with the calculations, particularly concerning the unknowns involved.
Participants note constraints such as the absence of information regarding the number of moles and temperature at certain points, which complicates their ability to calculate the required heat. There is also mention of specific heat values for a monoatomic gas and the need to clarify assumptions about the system.
Nellen2222
A monoatomic gas follows the process 1--> 2---> 3---> shown in the figure. How much heat is needed for (a) process 1-->2, and b process 2-->3 ?
Link: http://www.chegg.com/homework-help/questions-and-answers/monatomic-gas-follows-process-1-2-3-shown-figure-heat-needed-1-2-process-2-3-process-q1077907
Well, Volume changes so work changes. I calculated the work from point 1 to point 2. The change in volume was 200cm^3 which is 0.0002m^3. The pressure in atmospheres is 3, converting that to pascals is 303,975Pa.
I multiplied them together to get the area under the graph for work : (303975Pa)(0.0002m^3)= 60.795J
So now I have work. But this for some reason is not the answer.The answer is actually 150J, I just don't understand what to d ofrom this point
I know that Eth=3/2nRΔT , but i don't have moles so what can I do from this equation? I just don't know where to g ofrom here. Please help! Thanks.
The process from 1-2 is a constant pressure expansion. So what is the heat flow in a constant pressure expansion (hint: what is Cp for a monatomic gas?).
Without knowing Cp you can work this out using the first law and the ideal gas law: (1) Q = ΔU + W = ΔU + PΔV = nCvΔT + nRΔT for a constant pressure process.
AM
I don't understand what youre trying to say. Cp for a monoatomic gas is 20.8. How does that formula help me at al? I stil don't have moles, or ΔT at point 2.
Elaborate please..?
As far as I can see i have 3 unknowns. Q, n, and T for point 2. I still don't get where to go after calcilating work. I know i have to add q+w, I just don't know how to get Q.
Elaborate please..?
Assume you have one mole ie. that the question is asking for the amount of heat flow per mole.
From the ideal gas law PΔV = RΔT for a constant volume process. So ΔT = PΔV/R. The heat flow per mole is just Q = CpΔT.
Why are you interested in the work? 1-2 is at constant P and 2-3 is at constant volume. If you want to determine Q just use Cp and Cv. All you have to do is find ΔT. I'll let you figure out the ΔT for the constant volume process.
AM
T is 60.795J/20.8 = 2.92 mol*k ... don't see where this is going still? for 1--2 the answer is 150J, I am still not seeing it..
You know the temperature in state 1. Use the ideal gas law to determine the amount of gas. With the ideal gas law, you also find the temperature in state 2.
ehild
Im not getting it... your saying I know heat at point 1 which is 100deg celsius i agree, i find heat at point 2 with the ideal gas law and i get 74.6K at point 2... now what... Its been hours, can you please direct me withalot more clarity so I can move on with my life?
T2 is not 74.6 K. According to the ideal gas law, P1V1/T1=P2V2/T2. P1=P2 so T2/T1=V2/V1. V1=100 cm3, V2=300 cm3 and T1=373 K. What is T2?
ehild
  • · Replies 19 ·
