How Much Ice is Required to Cool a Whale's Tank from 20°C to 10°C?
  • Thread starter Thread starter mizzy
    Calorimetry
The problem involves determining the mass of ice required to cool a whale's water tank from 20°C to 10°C. The tank holds 1.20 x 103 m3 of water, and the ice starts at -10°C.
  • The original poster attempts to organize knowns and unknowns in a table format but expresses uncertainty about the temperatures involved in the phase changes of ice and water.
  • Some participants suggest using the concept of density to calculate the mass of water based on its volume.
  • Others propose calculating the heat transfer required for the water to cool and how much heat the ice can absorb during its phase changes.
The discussion is ongoing, with participants providing guidance on calculating the mass of water and the heat transfer involved. There is no explicit consensus yet, as various interpretations and approaches are being explored.
The original poster mentions needing to find the mass of water and is unsure about the temperatures for the ice and water phases, indicating potential gaps in information that are being addressed in the discussion.
mizzy
What mass of ice at -10.0 degrees celsius is needed to cool a whale's water tank, holding 1.20 x 10^3 m^3 of water, from 20.0 degrees down to a more comfortable 10 degrees.
Q = mc *delta T
Q = mL
i'm trying to fill out a table with knowns and unknowns before I actually solve the problem. This is what i got, can someone help me with the temperatures?
ICE: mass = x
c = 2090 J/kg C
Ti = -10.0
Tf = 0
MELT: mass = x
L = 3.33 x 10^5
ICE - WATER: mass = x
c = 4190
This is where I'm stuck what's the temperature?
Ti = ?
Tf = ?
WATER: mass = ??
c= 4190
Ti = 20.0
Tf = 10
Can someone let me know where i went wrong?? I still need to find the mass of water.
Thanks!
Do you know the concept of density? as in mass per volume? you can use that to calculate your waters mass.
As for the final temperature of the water you should calculate how much heat it needs to give up. Then see how much heat the ice can give up...
Yes, i know about density. To get mass, just multiply density of water and volume given.
then you can use that to get the heat water needs to give for the temperature drop. Then you can use algebra to solve for the change in the ices temperture/ melting.
  • · Replies 17 ·
