What is the initial temperature of the heated aluminum bolt?
  • Thread starter Thread starter Mr.Helms
The initial temperature of the heated aluminum bolt can be calculated using the principle of conservation of energy, where the heat lost by the bolt equals the heat gained by the water and the copper calorimeter. The correct formula to use is Tf = (m1C1T1 + m2C2T2) / (m1C1 + m2C2), but it must include all three masses: the aluminum bolt, the water, and the calorimeter. The user initially calculated a temperature of 541.3°C, which is incorrect due to neglecting the mass of the copper cup and the water in the equation. Properly accounting for all components will yield the accurate initial temperature of the bolt.
  • Understanding of heat transfer principles
  • Familiarity with specific heat capacity (C) values
  • Knowledge of the conservation of energy in thermodynamics
  • Ability to manipulate algebraic equations
  • Review the concept of specific heat capacity for aluminum, water, and copper
  • Learn how to set up energy balance equations in thermodynamic problems
  • Practice solving calorimetry problems involving multiple substances
  • Explore the implications of temperature changes in thermal equilibrium scenarios
Students in physics or chemistry courses, educators teaching thermodynamics, and anyone involved in calorimetry experiments or energy transfer calculations.
Mr.Helms
An aluminum bolt has a mass of 21.3 g. It is heated then placed into 839 g of water in a copper calorimeter cup with a mass of 137 g. The initial temperature of the water and the copper cup is 16 oC. The bolt, water and cup arive at an equilibrium temperature of 18.4 oC. What was the temperature in degrees celsius of the bolt before it was placed in the water?
I used this formula and got wrong answer, need help.
And got 541.3 Degrees C. What is wrong.?
I see three masses in the problem statement and you only have two in your equation...
It's never a good idea to write a one line answer, because this will usually give incorrect results. First observe that the heat (heat, not temperature) lost by the bolt is equal to the heat gained by the calorimeter and the water. Figure out how to express the heat loss and the heat gain in terms of temperature. Pay careful attention to the sign of your delta T's. And then finally, solve for the desired quantity.
sounds like homework to me.
23K
10K
