How does soap water membrane thickness affect surface tension?
The discussion focuses on the relationship between soap water membrane thickness and surface tension. It is established that a decrease in membrane thickness, while maintaining constant concentration, leads to a reduction in surface tension due to the increased mobility of soap molecules. Conversely, as the soap water membrane evaporates, resulting in decreased thickness and increased concentration, surface tension increases due to the higher density of soap molecules at the surface, enhancing cohesive forces.
  • Understanding of surface tension principles
  • Knowledge of soap chemistry and its properties
  • Familiarity with concentration effects on solutions
  • Basic grasp of evaporation processes
  • Research the effects of surfactants on surface tension
  • Explore the role of concentration in soap solutions
  • Study the evaporation process and its impact on liquid properties
  • Investigate experimental methods to measure surface tension
Chemists, material scientists, and anyone interested in the physical chemistry of solutions, particularly those studying surfactants and their effects on surface properties.
Chain Shawn
Homework. Moved to Introductory Physics.
1.If the thickness of soap water surface decrease, whereas the concentration remain the same, how will the surface tension change?
2. If the membrane of soap water start to evaporate, its thickness become thinner and it’s concentration increase, How will the surface tension change?
Thank you!
Please show your own attempt at solving the problem.
Thank you!
PF rules require that you show us your best efforts in answering these questions before we can offer tutorial help. Please show us what you have done so far...
  • · Replies 29 ·
  • · Replies 18 ·
  • · Replies 32 ·
