How to build a device to measure in angstroms
To build a device that measures in angstroms, an interferometer is recommended for its precision. The design requires calculating the screw's threading to ensure a specific number of turns corresponds to a small distance, such as 10 angstroms. Amplification of movement is crucial, as angstrom-scale changes are too minute for direct observation or manual manipulation. Additionally, the ends of the measuring device must be designed to avoid damaging delicate samples. Overall, careful engineering is necessary to achieve the required accuracy at such a small scale.
h3x3n
[SOLVED] how to build a device to measure in angstroms
Hello,
I was looking at a micrometer and wondered how one could build a similar device for meauring in angstroms. Could someone point to some theory that discusses the same ( for example if i have to forge a screw what would be its parameters)
Regards,
h3x
You use an "interferometer" to measure in angstroms.
To work out the parameters of a screw version, you'd have to work out how many turns of the screw had to correspond to 10 angstroms (say) - which tells you the threading.
Then you need something to amplify the change - since an angstrom is too small to see: you won't be able to read the scale let alone the vernier. For that matter, you'd have trouble marking out scratches an atom-width apart. So you really want the thing to be geared so that y millimeters movement in the scale corresponds to x angstroms movement at the ends.
You'd have to do something about the ends of the clamp too since the sorts of things you need to measure to angstrom scale are likely to get damaged by the usual screw micrometer ends. Note that such a scale is too fine to be manipulated by hand.
Thanks a ton for quick and effective response
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
