How to Calculate Acceleration on the X Axis Using Tri-axial Accelerometers?
  • Level: High School
  • Thread starter Thread starter Murs
8 replies · 4K views
Murs
Hi,
I am very new to accelerometers and I don't seem to be making any head way with them and I was wondering if someone could tell me what would be my first step in calculating acceleration on the X axis.
Well the tri-axial bit is irrelevant if you're only considering one axis. What type of accelerometer do you have, and what are you using to measure its output?
Hi,
I am concerned with all the axis( X, Y, and Z ) but I figured if I was told how to find one. I would be able to figure out the others. I am using a ±1.5g Three Axis Low-g Micromachined Accelerometer. So far all I am seeing are the accelerometer ADC values
19.405 2318 2038 2037
19.605 2320 2044 2036
19.805 2323 2049 2035
In the Format: <timeSec> <accX> <accY> <accZ>
The problem is I don't know what to do with these values to find the acceleration in each of the axis.
I only worked with an acceleromter briefly 2 years ago as a freshman project, but shouldn't there be some sort of rating for the meter (I think the one I worked with happened to be .01v/g). Knowing the voltage output you can calculate acceleration.
I did only get a B for the course due to troubles with hooking it up to an 8-digit display, so I probably don't know what I'm talking about. :P
Hi,
The voltage output for the
XOut @ 0g = 1.65V
YOut @ -1g = 0.85V
ZOut @ 0g = 1.6V
I would greatly appreciate it if you could tell me how the voltage output can help you calculate acceleration - Or anyone else that knows and can help me
Thanks!
A spec sheet for your accelerometer may help. Do you have a model number?
MMA7260Q
Located @ http://www.freescale.com/files/sensors/doc/data_sheet/MMA7260QT.pdf
Thanks
You have a zero point and a sensitivity for each channel. Basically, using the values given in your data sheet (and comparing to what you've posted):
Acceleration (g) = (Output in mV - Zero point in mV) / (Sensitivity in mV/g)
So for example...
Acceleration (g) = (850 mV - 1650 mV) / 800 mV/g = -1g
Hope this helps.
