How to Calculate Average Power and Roller Coaster Speed on the Moon?
To calculate average power while cycling, use the formula power = energy/time, resulting in approximately 23.33 kilocalories per minute when 700 kcal is expended over 30 minutes. For the roller coaster problem, the gravitational force on the Moon is 1/6 that of Earth, affecting the speed at the bottom of the track. The conservation of energy principle applies, with potential energy converting to kinetic energy, allowing for a comparison of speeds on both celestial bodies. It's important to maintain consistent units throughout calculations for accuracy. The discussion concludes with a successful resolution of both problems through collaborative input.
aforce20
I really need help on these two problems, I am not sure where to start and for that reason I do not have an attempt at the problem. I am not asking for anyone to do them for me , but could somone give me the equations or the steps needed to solve?
1. I expend 700 Calories (food or kcal) in riding my bicycle for 30 minutes. What was my average power during my ride?
2. NASA builds a 100 meter high roller coaster on the Moon. The gravitational force on the Moon is 1/6 that of earth. Will the roller coaster car being traveling faster at the bottom of the track on the Earth or the Moon. How much faster or slower will it be going?
Hi aforce20,
Do you remember how Power defined? It's the amount of energy used per unit time. Perhaps that will help you with the first problem.
For the second problem, are you familiar with the concept of conservation of energy?
The formula for kinetic energy us E_\textrm{kinetic} = \frac{1}{2}mv^2 where m = mass and v = velocity. For potential energy in a gravitational field is E_\textrm{potential}=mgh where m = mass, g = acceleration of the field, and h is your height. See if that helps
This is what I have for #2, the speed of the roller coaster with Earth's gravity. Does this look right? And how would i find 1/6 of Earth's gravity?
and #1 I came up with this, don't know if it is correct or not.
What you have written: work = power/time, is simply not true. As yaychemistry said, power is the amount of energy used per unit time.
Always include units in your calculations, otherwise your numbers are meaningless to everybody else. For example, for g you substitued 98.2. Since we don't know what units that is in, we have no way of telling whether that is right or not (if you are using SI units, then it is not the right value of g).
As for how to take into account the moon's gravity being six times weaker, consider this: You have three parameters given: m, g, and h.Of the three, which two are the same on the Earth as on the moon? Which one is different?
ok here's my revised #2
I still can't figure out # 1
Assuming that your arithmetic is right, then I can't see anything wrong with #2. Why did you round 9.82 up to 10? Did your teacher say it was okay to use 10?
For number 1, power = energy/time. The energy expended is given. The time is given.
1. P=\frac{E}{t} where in this case: P = \frac{calories}{time} (remember to use the units in your final result)
Therefore, E=Pt. and NOT E=\frac{P}{t} like I noticed happened before :smile:
2. You seem to be doing well with this one, all you need is the difference in speeds - which I'm sure you've already done - and you're set.
The only reason I rounded to 10 , was because the example in the book did the same thing so I figured it was ok to do so, but now that you say something I think I should just keep it as 9.82
So for #1
power= energy/time
=700kcal / 30 minutes
=23.33
^ This is the answer, the average power during the ride ?
in units of kilocalories per minute, yes it is.
Thanks to all that helped me with these two problems. Your help is very much appreciated!
