antiderivativ
- 17
- 0
Hi! Could someone please check if my following problems are correct? Any insight on why a problem is incorrect would be appreciated. Thanks!
1) An object is hung from a light vertical helical spring that subsequently stretches 2.0 cm. The body is then displaced and set in SHM. Compute the frequency at which it oscillates.
2) A 5.0-g bullet is fired horizontally into a 0.5-kg block of wood resting on a frictionless table. The block, which is attached to a horizontal spring, retains the bullet and moves forward, compressing the spring. The block-spring system goes into SHM with a frequency of 9.0 Hz and an amplitude of 15 cm. Determine the initial speed of the bullet
