How to calculate how a weight added to the top of a sailboat mast affects COG
  • Context: Undergrad
  • Thread starter Thread starter Greg2
    Cog Weight
The discussion revolves around how adding a weight to the top of a sailboat mast affects the center of gravity (COG) of the boat, particularly in the context of open ocean cruising. Participants explore theoretical implications, practical considerations, and the balance between stability and performance in sailing.
  • One participant seeks to understand the effect of a 1 kg mass at the top of the mast on the COG, assuming a known initial COG relative to the waterline.
  • Another participant introduces the concept of a weighted average to calculate the new COG, providing a formula for the calculation.
  • A participant reflects on the minimal impact of a 1 kg weight on an 8000 kg boat, estimating a shift of less than 1 cm in COG.
  • Contrasting views arise regarding the significance of the weight; one participant argues that a substantial keel weight is needed to counterbalance the weight at the mast top, while another considers the weight inconsequential for cruising purposes.
  • Participants discuss the implications of adding larger components, like roller-furling sails, on stability and the Angle of Vanishing Stability, noting that such additions can significantly affect performance.
  • There is a mention of the trade-offs between speed and stability, particularly in the context of racing versus cruising sailboats.
  • Some participants share personal insights about sailing experience and the challenges of managing sails, especially for single-handed sailors.
Participants express differing views on the significance of the weight added to the mast and its implications for stability and performance. The discussion remains unresolved regarding the extent to which a 1 kg weight is consequential in practical sailing scenarios.
Participants reference various assumptions, such as the initial COG location and the weight distribution of the boat, which may influence the calculations and conclusions drawn. The discussion also touches on the practical realities of sailing that may not directly relate to the physics involved.
Greg2
I'm in the process of purchasing a sailboat for open ocean cruising and would like to understanding how a mass (say 1kg) mounted at the top of the mast affects the center of gravity, assuming that the COG is at a known location relative to the waterline.
Are you familiar with the concept of a weighted average?
I understand the concept, but wouldn't say that I'm terribly familiar with it.
I imagine you have 'looked it up' and that what you have found didn't seem relevant to your particular situation.
This link tells you what you need to know about the basics. ~The COM of an object is the point about which the object would balance. It's the point about which the turning effect of all the parts on one side is balanced (equilibrium) by the turning effect of all the parts on the other. It is best to start thinking in terms of a 1D object (a rod with masses on it) and then work towards 2D (a plate) and then 3D (a solid object)
If you take a point to one side of the COM, there is a net turning effect (no equilibrium) which can be eliminated by putting another mass somewhere on the other side of the new point and then the new point becomes the new centre of mass. Your boat problem can use the COMx formula with just two masses; the mass of the boat and the added 1kg. Use the bottom of the keel as the reference for distances. The new COMX position will be
COMnew = (Massboat . COMboat + Mass1kg. Height above keel)/(Massboat +Mass1kg)
An in your head calculation will tell you that the shift will be about Mast height.(1/Massboat)
OK, that should be enough. The COM of a system of multiple objects is the weighted average of the COM of each individual object. So if x is the position of the COM and m is the object mass then
$$x_{total}=\frac{m_{boat}x_{boat}+m_{weight}x_{weight}}{m_{boat}+m_{weight}}$$
Thanks for the help (with clarity).
For the record, given an average 8000 kg sailing vessel with a 17 meter mast, we're talking a movement of the location of the COM upwards from the keel of less than 1 cm. Upon reflecting as to how I might have tested this with a scale model, it's obvious now that a 1 kg weight at the top is nearly inconsequential given the weight of the boat.
Next time, perhaps I'll start from that end of the problem.
No problem! At least you had thought about it enough to clearly specify the problem, and it was a problem that has a fairly direct and clear answer.
If you consider that the weight of the keel is probably only a meter or so from the CG of the boat, you can see that nearly 17 kg of keel weight is needed to compensate for 1 kg at the top of the mast, so not exactly inconsequential. This is the reason manufacturers of racing sailboats go to all the trouble (and expense) of, for instance, tapering the top of the mast.
Good point. I had not considered the racers point of view. I approached the problem from the conservative cruiser point of view - sacrificing some speed for stability.
Yes, for that purpose 1 kg is probably not significant. Note that adding something as substantial as a roller-furling sail can reduce the Angle of Vanishing Stability as much as 10 degrees from the original design.
Fortunately, we're quite happy to sacrifice a bit of convenience for better stability, so no roller-furling sail for us.
For many people it's more than just a bit of convenience. Getting up on the foredeck and changing foresail frequently is a lot to ask of many cruising sailors especially single handers. The compromise to suit everyone is to have a lower mast, I think. But that's sailing and old age and not Physics. :wink:
Point taken. We'll likely reach that point once we get more experience under our belts. We're just getting started.
I don't know how long it takes before a newbie sailor stops being chicken long before the boat does. I hope you never get to the stage where the Angle of Vanishing Stability is a serious issue for you. It won't be until you get to be one of those nutty gung ho racing types. :))
Hey! I resemble that remark! But the OP did mention open ocean cruising, so there is the faint possibility of being caught broadside by a big wave. However, I agree with you, on a 17 meter mast I really want roller furling (at least on the headsail.)
Nothin personal but you must have come across racers who seem to put health and safety behind them in the interests of getting a win. It's mostly testosterone driven and few of them would expose their partners and families to the same risks. They are just wealthy versions of the (mostly) young men who cycle against traffic lights and up one way streets with their personal force field switched on.
Roller furling gives you the chance to reef when you like and however much is needed. This protects you against the not-so-freak conditions that can hit you with a too-massive headsail up there. I'm all for an easy life, personally - particularly on a long cruise.
  • · Replies 49 ·
12K
