Undergrad How to calculate the area under a curve
To calculate the area under the curve of the Folium of Descartes defined by the equation x^3 + y^3 - 3axy = 0, a definite integral approach is necessary. Simply integrating the function without distinguishing between the top and bottom parts of the loop will not yield the correct area. It is essential to identify the functions that represent the upper and lower sections of the loop separately. By integrating these functions over the appropriate intervals, the area can be accurately determined. This method ensures that the complexities of the curve are properly accounted for in the calculation.
JG FRANKO
I was doing some integral exercises for getting area under the function. I was doing only more simple stuff, like functions that don't go over the same "x area" multiple times, like a quadratic function. My question is how to calculate area of a loop in an equation x^3+y^3-3axy=0 if let's say a is 1.
Thank you for your answers in advance
If I create a function out of this equation, I get
Would the answer be correct, if I would use a definite integral to integrate this function to get the area of the loop?
Likes Nucleus _Basalis
Likes Nucleus _Basalis and Buffu
The function you have will certainly won't give you the answer if you integrate it alone. You need a function for top part of the loop and one for the bottom part of the loop. On the top part the function is increasing and decreasing on the bottom part.
  • · Replies 20 ·
  • · Replies 24 ·
