The discussion revolves around calculating the horsepower required for a small hatchback car based on its weight, top speed, aerodynamic drag coefficient, and tire radius. Participants explore various methods for engine sizing and power requirements, including theoretical calculations and practical considerations.
- Technical explanation
- Mathematical reasoning
- Debate/contested
- One participant asks how to calculate horsepower given the car's weight (950 kg) and top speed (144 km/h), along with other parameters.
- Another participant suggests that the majority of power at terminal velocity is due to drag, estimating the required power to be about 37 kW (50 hp) for a car with a frontal area of 1.5 m².
- A participant inquires about sizing the engine for a small hatchback, seeking clarification on what "size" means in this context.
- One response indicates that while 50 hp might be sufficient for top speed, more power would be needed for acceleration, suggesting around 60 hp for a budget hatchback.
- A detailed example is provided for calculating engine specifications, including assumptions about brake mean effective pressure (BMEP) and maximum port velocity.
- Another participant argues that the information provided is insufficient for detailed engine specification, emphasizing the need for additional data such as fuel type and injection method.
- A participant presents a formula for calculating horsepower based on weight and velocity, yielding a value that seems high for a small car.
- Discussion includes estimates of power losses due to aerodynamic drag, rolling resistance, and internal resistance, with varying opinions on the accuracy of these estimates.
- One participant expresses uncertainty about the calculations for aerodynamic drag and other forces, leading to further clarification and corrections from others.
Participants generally agree that aerodynamic drag is a significant factor in determining power requirements, but there are multiple competing views on the specifics of engine sizing, power calculations, and the assumptions made in those calculations. The discussion remains unresolved with differing opinions on the accuracy of various estimates and methods.
Participants note limitations in the data available for calculating BMEP and port velocity, as well as the need for assumptions regarding engine design and operational parameters. There is also mention of potential losses due to transmission efficiency that have not been quantified in detail.
